XCRUISER.XDSR420HD.v2.11.87 Исправлены все косяки более ранних версий качаем:http://dfiles.ru/files/5qhk5fqcz
Release note Version 2.11.87 1. DNS setting by force for stable YouTube connection
First DNS : 8.8.8.8 / Second DNS : 8.8.4.4
2. YouTube Category rearranged based on changed YouTube category
(Top Rated / Top Favourite / Most Viewed Removed)
3. Connectivity of AirTivi+ under WiFi network : Improved
4. Weird character in FAV List after choosing Persian : Solved
5. Incorrect Quality level : Solved
6. Parental control for Media, web browser, TV Portal+ : Added
7. Asking for REBOOT, DEEP Standby, Standby when pressing and hold power key on remote : Added
8. Short cut key(Recall button) to make video full screen in Torrent Player : Added
9. Channel recording will be continued even if the channel get Scrambled and De-Scrambled : Added
10. Receiver freezing after few hours if leave it on MENU OSD : Solved
11. Receiver will change the resolution according to the channel resolution : Added
12. Compatibility with plugin Xcam2 and Mcas : Improved
13. Starting plugin by Green will start the plugin without asking YES/NO : Added
14. Time Calibration : Added
=> Getting the correct TIME info from satellite transponder and make the EPG available with correct time information
