NEW RELEASE r8264: Added or improved Function
1. The video player(Divx 3,4 and xvid, mpeg 2, H.264)
: video player can support some file formats such as *.avi, *.mpg and *.mpeg.
you have to change the extention as *.avi, *.mpg and *.mpeg before playback.
press pause : pause state
Pause> pause : pause state
Play button only can be exit from pause mode.
Sometimes, If the file needs higher class CODEC than current one, it may be not played.
If the file itself too high bitrate, it may be not played.
The version of Divx CODEC more than 5.2 doesn't support it.
2. WebTV on webinterface
: First of all, you have to install VLC Player on your PC.
It's tested on Firefox and Internet Explorer 7.
Javascript is required.
Streaming works for 720p channels, but for 1080i there is not enough network bandwidth.
USAGE: Surf to
http://(boxip)/webtv/
3. ITV HD(Astra 28,5)
: it should use Advanced Search menu with manually (3401 VPID, 3402 APID, 2326 PCR PID)
http://www.flysat.com/28east.php
4. improved to related USB HDD
: 1 channel recording in a TP and 1 recorded file playback or 1 another channel watching in the same TP.
5. improved channel zapping speed
6. Solve the bug of the USALS
7. Solve the bug of the Diseqc 1.2.
8. Support HDD sleep
: If select timeshift off, HDD willgo sleep mode after 3 minutes.
9. Update DB for DVB-T and DVB-C
: Ireland MMDS(Terrestrial), IRE6887 Quick(Cable), ENG6952 Quick(Cable)
10. improved to related plugin
11. channel list of Grid EPG follow channel sorting
12. bug fixed static IP
13. Added FAST SCAN function for Benelux
known issues
: WSS in Recorded Files.
: HDMI with compressed Dolby digital audio
: DVB subtitle
Above all, we can confirm the effect in the DGSTATION enviroments.
We cannot be sure of the same result.
If not so, contact with us.
e-mail:
[email protected]
Thank you.
