SifTeam 0.1.9r8718 ipbox9000-900-910 HD
1. Added "post-descrambling with CAM" function on system settings menu
: When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
and then you can descramble the recorded file later.
- The channel in record cannot be watchable.
- The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
- even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
(Caution)
The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
If descrambling is not running, it is impossible to do the file descrambling anymore
or able to damage the smartcard since the smartcard has already been updated.
2. Added HUB function for USB host.
3. Fixed record programs with DVB subtitle.
4. Support adjust LipSync using page up/down buttons in Videoplayer
5. Support NFS function for Linux System in Mount manager
- changed NFS config in /etc/exports
ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
- Removed the firewall of system
- Removed the firewall of IP table when your system is Fedora
# iptables -F
6. Support displays elapsing time on banner of MP3 player
7. Support Sort function on TMP folder in Recorded files menu
8. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
9. Updated language table for Slovak, Bulgarian, Polish and Russian
10. Fixed DVB EPG bug for HB13 10891
11. Fixed elapsing time error when schedule recording.
12. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
13. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
14. Added WSS function through SCART
брать здесь:
[/HIDE]
