Не идёт шаринг на Кате.
Mike1969
zabor,
Я вначале включал DHCP, убеждался, что в и-нет ходит нормально (ОСД меню), потом полученные значения(шлюз, ДНС) присваивал руками и DHCP отключал. Если поможет...
denn7
По логу я не вижу чтобы катя шла в инет,
Тоже не ясно.
Выложи сюда настройки свои mg_cfg
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 01 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
U: { 01 }
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
G: { 01 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 01 } 5 30
# network ecm timeout in seconds
K: { 07 }
# newcamd dead routes connect retry, sec
Q: { 15 }
# network shares priority
# 00 gbox, newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd, gbox
# 02 newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 } YYYYYY XXXXXX
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 03 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 01 } 192.168.1.1 /tmp/mgcamd.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 00 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 00 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 04 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
B: { 00 }
На счет инета не могу понять. я уже проверил файлы network,ipaddres, ethernet все там правильно. а тюнер в инет не выходит cудя по логу.
Добавлено через 7 минут
и не забудь сменить сам эму mgcamd "mgcamd v1.29"- он у тебя старой версии - не будут работать каналы с длинным ECM
скажите пожалуйста а можно тупым копированием заменить 1.29 на 1.31 в директории emu ? .у меня на 1.29 еще пару файлов находяться в emu например emustop,pl2303,usbserial, при загрузке имджа они там появляются.или же надо имидж поменять для установки 1.31?
Mike1969
Цитата:
Сообщение от denn7
Проще тупо зайти в доп. меню, удалить все эму и залить новый мгкамд с сервера
...или прошится имиджем с нормальным эму (MOD_VITGRAF_GEMCHUG74 например) ...
n@mo
конечно можно, это гораздо проще и безопаснее,чем прошивать новый имидж (при необходимости менять версию эму)
denn7
Решил проблему.Поставил имидж dominica mod4. там эмулятор со всеми необходимыми файлами. внес свои данные. и НТВ заработал как SD так и HD:)
следующим этапом будет настройка 5 спутников. где-то была инфа на форуме что можно слепить disec1.1 так как 1.0 мне не подходит.
в предыдущем посте не правильно указал имидж.сорри. правильно domica mod4
Mike1969
Так и я про то ж! Прошился, вначале, чем-то со старым эму, переписал его на 1.31, ничего не работало... Потом поставил MOD_VITGRAF_GEMCHUG74 (усоверш Domica mod4) со своим эму. И все сразу пошло!!
Короче, поздравляю!
zabor
распиши как организована сетка для выхода в инет
ps набери в командном окне команду ipconfig -all и посмотри какие адреса используются
Извините вчера жена не дала поработать. Праздник однако.:pardon:
Сеть состоит из следующих устройств:
Тел линия в модем IDC 2814BXL модем подключен к компу.
В свойствах соединения протокола TCP -получать ІР автоматический
Через сетевуху подключена к компу Катя (вісокоскоростное соединение)
Стоит имидж от ААФ 2.0д mod vitgraf Через КСС все пингуется
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet addr:192.168.1.25 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:65 errors:0 dropped:0 overruns:0 frame:0
TX packets:983 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4405 (4.3 KiB) TX bytes:278632 (272.1 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:54 errors:0 dropped:0 overruns:0 frame:0
TX packets:54 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4972 (4.8 KiB) TX bytes:4972 (4.8 KiB)
Припроверке шарика выдает:BusyBox v1.2.1 (2007.10.12-18:30+0000) Built-in shell (ash)
# Kathrein UFS-910 ROOTDIR
/bin/sh: Kathrein: not found
Написал в личку для n@mo
denn7
Короче, поздравляю!
Вообщем не долго радовался- решил закрепить успех и настроить что то типа Diseg 1.1 не получилось . вообщем сбил где-то конфиги.
пришлось перезалить имидж по новой. шара пока не идет. так как и не идет открытые каналы на 36Е. Честно говоря не думал что такой вроде бы несложный механизм поиска каналов и спутников на Кате выполнен кривовато как по мне. На другом тюнере openbox820 настройка каналов и спутников летает на ура.
Mike1969
Да, настройки каналов надо сохранять, канэчна...
witali4
Здравствуйте, скинте пожалуйста в личку адресок нормального сервера от куда поШАРИТЬ можно, а то не могу найти. Особо интересует Платформа НD на Eurobird 9E
Благадарю заранее!
zabor
Благадарю заранее!
Присоеденяюсь к просьбе:taunt: Если можно и мне тоже.Спасибо.
zabor
Кто подскажет чего не так по логам Пявились следующие вопросы.
1 По телнету:
/bin/sh: Kathrein: not found Почему?
# ~ # killall mgcamd
/bin/sh: /: Permission denied
2 По логу шары:(kiwi syslog)
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 /data/keys/tps.bin error 2: No such file or directory
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 [mgcamd] tps update started.Онже отключен?
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 [mgcam] emm thread started
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 newcamd keep alive: 300, incoming port: 12000
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 [config] newcamd route = e697****:cse****.net:10*** server cardserv
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 Conax.Key error 2: No such file or directory
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 Keys readed
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 Conax.Key error 2: No such file or directory ???
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 Box type: stapi
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 [mg] Ecm cache time: 15
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 [mg] Net:1:0:2:5s Show ecm:1, emm:2 Up:1 Au:0 Dir:0 Osd:no:80:0 Cache:0 Log:1:192.168.1.3:514 Reread:2
03-15-2009 10:45:55 Local7.Debug 192.168.1.100 tuxbox mgcamd v1.31 by mixvt (compiled Oct 27 2008 23:09:59)
03-15-2009 10:45:36 Local7.Debug 192.168.1.100 [newcamd] Login to cse***.net:10*** as e697**** failed (244ms)
03-15-2009 10:45:35 Local7.Debug 192.168.1.100 [mg0] pid 0x0078 failed to decode.
03-15-2009 10:45:35 Local7.Debug 192.168.1.100 [mg0] network can't decode
03-15-2009 10:45:35 Local7.Debug 192.168.1.100 ECM: CaID: 0x4AE1 -> CaPID: 0x0078 ProvID: 000000
03-15-2009 10:45:35 Local7.Debug 192.168.1.100 [mg0] service 32 index 0 pmt pid 0 (1)
03-15-2009 10:45:35 Local7.Debug 192.168.1.100 [newcamd] Connecting to cse***.net:10***...
allllex
Тебе же эмулятор ответил:
Неправильный логин, или пароль.
Остальное, это не ошибки. Пусть обновляет, только обновлять нечего.
zabor
По командам понял свою ошибку. Спасибо! Будем копать дальше.(Искал в инете команды "Телнет" но они с катрейновскими по "help" не совпадают)
Alex Kholin
Что с Релсат?
Может не совсем в тему, но ответьте, если у кого-нибудь есть информация. Уже третий день не идёт шара через www.relsat.org. Не откликается их сервер. Даже сайт не открывается, поэтому спросить их невозможно. Что случилось? Если здесь эта тема неуместна, то откликнитесь в личку. Спасибо.
