ka-igr
Наконец после почти 4-х месяцев молчания (09.09.2010 был выпущен в свет AAF Hot Summer) AAF выпустила в свет новый имидж AAF_MME_UFS910.
AAF_MME_UFS910_USBFull
(Uploader: Thomas4711)
am: 24.12.2010 18:48
Beschreibung:
AAF Multimedia Edition UFS910 FullUSB
Image Info
AAF Enigma2 MultiMedia Edition (Image 25) Changelog:
SH4 Duckbox Projekt:
+ Libeplayer3 (besseres Streaming Verhalten/mehr Stabilität bei Wiedergabe)
+ Better performance when jumping through recordings during playback
+ fix dma bug
+ Fixed sporadic hangs during playback also in Diff4
+ bugfix from Schischu regarding hanging while loop
+ fix help menu and softwaremanager
+ fix unknown mp3 audio selection
+ Fixed GS when Teletext is invoked an no tuner is configured
+ [ffmpeg] add videoshoot support and convert jpg > mvi support
+ [ufs912/atevio7000] merge stv090x; ORF bugfix
+ fix a bug in libeplayer3 handling
+[ufs922] evremote2 --> must fix epg_key
+ [evremote2] Change atevio7000 handling
+[nuvoton] now uses irq instead of polling
+ [micom] bugfix
+ [ufs912, 922] micom now uses irq to receive fp events. longkeypress support
+ [evremote2] enable longkeypress for Atevio7000
+ [ufs912] fix avi reboot bug
+ [ufs912] Tunertreiber aktualisiert
AAF:
+ Overclock/Übertakten (außer UFS-912)
+ fix PIP zoom
+ PluginBrowser Preview Support (standard)
+ Cardreader Support (at700/7000)
+ AafPanel Icon Support
MediaCenter Update:
VideoPlayer:
+ Cover Ansicht (4x3 cover like Xbox Xbmc)
+ Fullcover Ansicht (like ProjektVallery)
+ Cover/imdb download von Imdb/TheMovieDbProvider/TheTvDbProvider/Mtv integriert
+ Cover und infos fuer Filme/Serien/Musikvideos
+ Automatisches Update der IMdb Daten moeglich
+ Special Folder support fuer Cover Ansicht (Ordner mit Serien/Section Bilder like Xbox Xbmc)
+ Random (Shuffle Support)
+ Verbesserte Steuerung
+ Apple Movie Trailer (außer TF7700)
+ MyVideo Player
PicturePlayer:
AudioPlayer:
+ Screensaver (Title Text)
+ Screensaver (PNG1)
+ Screensaver (PNG2)
+ Screensaver (MVI SAVER)
+ Screensaver (MVI IMDB)
Webinterface Update:
Webinterface auf version 1.6.2 upgraded
+ add AAF-Panel
AAF-Panel:
+ add SoftcamPanel
+ add FlashUpdate
+ add Backup&Restore
+ add ImageInfo
+ add OverClock over WebIF (bis auf UFS-912)
+ Screenshot Video und ALL
Качаем http://www.aaf-board.com/wbb2/database_arc.php
Добавлено через 24 минуты
Установил AAF_MME_UFS910_USBFull на mini-раздел через MPI_2.1 без проблем.
Заменил satellites.xml в папке etc/tuxbox так как не было нужных мне спутников, забросил свои сеттинги. Эмулятор MgCamd 1.35 скачал через Меню-Плагины, понравилось то, что и сам эмулятор и конфиги для папки keys качаются сразу одним плагином. Для запуска эмулятора отредактировал mg_cfg поставил:
А: {02}
G: {01}
K: {02}
Перегрузил ресивер, все заработало сразу и без проблем!
Grey_
Заменил satellites.xml в папке etc/tuxbox так как не было нужных мне спутников, забросил свои сеттинги. Эмулятор MgCamd 1.35 скачал через Меню-Плагины, понравилось то, что и сам эмулятор и конфиги для папки keys качаются сразу одним плагином. Для запуска эмулятора отредактировал mg_cfg поставив:
А: {02}
G: {01}
K: {02}
Как качество картинки?
metalzavod
ka-igr,
посмотрите, пожалуйста -есть ли возможность в данном имидже подключения WIFI, чтобы лишний раз не заморачиваться с установкой...
Барнаул67
понятно, как всегда стандарт ААF!bad!... не сомневаюсь, что поляки в ответ что-то новенькое выпустят!good!...
Извеняюсь, сам не пробовал, но по моему ета проблема уже давным-давно решена: http://www.aaf-board.com/wbb2/thread.php?threadid=20589
и так-же сейчас глянул, через аддон тоже скачивается.
metalzavod
спасибо за ответ, тогда буду пробовать... хотя нонсенс, для скачки аддонов нужен интернет :nea: !? у поляков монтируется Вайфай, а после настройка интернета... или здесь аддоны без интернета ставятся?
Mar500
прошу советы
зависание кати - и этот имидж ничего неизменил
состаяние
- вложена карта для приема Словак и Чешских програм - ICE - побробоал 3 вида карт - невключен никакой Softcam, инсталация E2 через МПИ - на УСБ 2 ГБ - пробовал розные до 8 ГБ
уже много времени есть у меня один проблем
зависание кати в любой E2 - после перегрузеня несколких каналов в НD качестве но не всегда - резултаты 2 смарткарт
1/или неработает ни один канал
2/или неработает смарткарт и тем кодироане програмы
Сейчась исползую CLONE+ на нее когда это слусится неработют лед диоды - думаю перерван связ с картой
Кати перегрузаю через несколько раза
*** это все неслучается при имидже ориг. тоже на ААФ 3.0 Бета - котороя находится
на УСБ**
Спасибо
marina71
На этом имидже шара открывается мгновенно,такого не наблюдается ни на одном имидже
По крайней мере-у меня после того как изменила настройки по подсказке Grey
Спасибо ему
skosarevk
Что нужно сделать,чтобы видеть описание передачи в нижней части скина,и вообще описание?Может кто знает?Пробовал отредактировать в юзр-локал-шаре-енигма 2-скин дефолт в разделе channel selection-tv в строке event name удалил extended и оставил просто description,перезагрузил,но не помогло.
gregvel
Если кого не затруднит, выложите прошивку, а то я не силен в немецком и не могу скачать, самому стыдно.
mihailp
Поддерживаю прозьбу! В скине infinityTV-HD все красиво кроме отсутствия описания программы в окне информации. По кнопке i осталось только аналогичные передачи. Редактирование скина приводит к ошибке загрузки. В педыдущем имидже все было нормально. Поправьте кто умеет!
skosarevk
VlaSky,какую соседнюю?Я вроде-бы просмотрел,но ничего не нашол.Если есть решение,то выложи ссылку пожалуйста.
skosarevk
birca1987, Это не помогло.Попробовал закинуть этот-же файл с HS-V2,результат такой-же.Но всё равно спасибо.
mihailp
Да, это не то. В этом имидже описание отображается корректно. Просто в нужном месте оно не прописано.
