Имиджи для AB IPBox 9000HD
Viraje
CubeRevo nlb svn8873 v1.27 for IP9000
[/HIDE]
Lenina
Куратор "IPBox"
Вышли официальные релизы для 900/910/9000
ABCom 8873 для 9000
[/HIDE]
Darkness666
AB_9000HD_230109_r8873
1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet. press once FF or REW button, the interval is 10 seconds. press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
2. Add Scan option on Channel Scan Menu When there is no channel list, all these options create with the same result. - Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list. - Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list. - Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
3. Add USB upgrade menu - Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode it is useful for software upgrade with USB morory stick.
4. Fixed EPG contents Display - inserted new line on the screen for EPG and extended EPG information
лежит тут
janigor
Addon version 230109 for AB Image
Remove Red button for key update, You can update keys only from webinterface.
Upgrade Newcs 1.65 version
For upgrade read instruction in Beginners guide for AB IPBox HD series on this website.
9000
janigor
Cli-5.0.0 -ip9000- Based on Abcom8873
Cli R8873
Based on Abcom 8873
Fixed from Abcom version:
---Fixed skins - default crash deepblue final
---Fixed plugins
---fix libs
---Fixed terminfo definitions for TOP command
Additions from abcom image:
- DGS/Cli web interface in one
- Mgcamd/newcs/ and other cams
- support for incubus/mbox etc on web interface cam control
- Cron Job support Micrond in /usr/local/bin
- inadyn in /usr/local/bin > please see /usr/local/etc/inadyn-config
- some extra plugins
Добавлено через 53 минуты
Sifteam r8873 Version 0.2.0 29.01.2009
Version 0.2.0
Added default password as "sifteam"
Added script "advanced.command.sh" ..for:
Add NFS disk
Remove NFS disk
Make USB for use as Disk (in congiuntion with NFS option is very good)
Move /var in part1 of disk or USB (part1 = first partition)
Removed any files (script)
Added script for see proper card permission
P.S.
Added other file ..and other basic option ?
[/HIDE]
janigor
DGS release r9047: ( 5/Mar/2009)
1. Added additional channel scan options for TV or Radio
2. Added repeat function in Video Player
3. Added navigation method for TTXT sub-channel
4. Display the summary when searching channel
5. Save the name of recorded file when user want to schedule in EPG
6. Fixed bug Toptext navigation with TTXT
7. Fixed bug which was CubeRevo always blocked when first boot After update
new software
8. Fixed bug which was CubeRevo-250HD and CubeRevo-mini were not updated
local timer after AC power off even with Automatic time setting
9. Fixed Alphacrypt German Language Encoding bug
10. Included some of the new plugins in CubeRevo SW version.
- Thanks as below developper for plugin.
They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
pong, sudoku, tetris, andd weather of Neumoteam.
11. Updated German language translated by Nilse
12. Removed subtitle language setting in Language Settings Menu
users control through subtitle option on RCU.
13. Modified pop up message 'Service is not available' disappears after 5~6
seconds automatically
14. Adjusted the position of Pillar box
15. Adjusted color table of DVB subtitle for some channels
Note.
1. Added Multi booting function
If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
Then press number button on RCU which you want booting mode.
Multi-booting support as below. Official image is number 3.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
2. The Digifilm channel works in official CAM.
known issues : sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
9000
4x6hp
SifTeam r9047:
подправил ссылку
Ссылка рабочая!!! Выберите в браузере английский язык!!!
[/HIDE]
chewbacca
Модератор "AzBox"
NLB r9047 ipbox9000HD
DGStation/Abcom CubeRevo Series NLB svn9047(binaries) v1.29
WEBIF
login: root
password: relook
FIRST TIME BOOTSCREEN PANIC IS FINALLY FIXED!
Prepared by : Dexter
Release date : March 7. 2009
Changes:
* updated - SVN9047+ sbox+skin binaries +po files only.
* plugins - updated favpip 2.1.0
* plugins - updated hddtemp 0.0.7
* plugins - all default in /var/plug-in again.
* emu - mbox 0.4 beta 0023
* webif - emu and newcs selection made simpler.
* skins - deepblue and grey updated.
* emu - EVOCAMD is no longer included in NLB image, no support for it.
* cardreader- DGS Release had problems with Nagra3 cards. this one works.
* DGS webif - updated Geckow webif to 1.3.1 (07.03.2009)
http://rapidshare.com/files/206451427/nlb9047.zip
ingvard-rus
AB (DGR based)release r9057: ( 10/Mar/2009)
1. Fixed Astra 23,5E, TP 11876, 11992 PANIC problen
2. Added additional channel scan options for TV or Radio
3. Added repeat function in Video Player
4. Added navigation method for TTXT sub-channel
5. Display the summary when searching channel
6. Save the name of recorded file when user want to schedule in EPG
7. Fixed bug Toptext navigation with TTXT
8. Fixed bug which was AB IPBox 91HD and 910HD were not updated
10. Included some of the new plugins .
users control through subtitle option on RCU.(this function will be back in next versions)
Note.
Images marked as "DRE" are especialy for DRE CAM modules use. If you donґt have this CAM, donґt use "DRE" version !
3) original images
7) boot from flash
3. This image include sci.ko and smart_core.ko
known issues :
USALS doesnґt initialized correctly after box crashed
nikomar
аддон с эмулятором для 9000
http://www.satupdate.net/stahuj/AB ...de for AB Images/SF_addon_for_9000ABr9057.zip
Порядок установки аддона:
SF addon for AB r9057 image
installation:
First update new image version r9057.
Unzip file, rename to "usb_update.img"
Use usb stick or flash tools for update. Is it same as image update.
По-русски
Устанавливаете имидж 9057
Разархивируете аддон из архива.
Переименовываете его в usb_update.img
Устанавливаете с флешки также как и обыкновенный имидж.
AB_9000HD_r9203_020409_usb_all_noboot.zip NEW!
1. Added 4:3 zoom function on 16:9 TV system
2. Added Ukraine language on the menu
3. Added Display with channel numbers on front display instead of the non-Latin characters
4. Keep the current file system without automatic format even though the file system is ext2 or ext3.
5. Fixed File name bug of the main recording event on EPG Schedule Record
6. Fixed CSLink panic on ASTRA 23.5E 11876
7. Fixed Web interface bugs(no RCU image, 91HD didn't work Web interface, etc) and Update Web interface version
8. Fixed Display strange EPG time info on the banner
9. Fixed Subtitle sync.
10. Fixed Audio jerky on BadrC(26.E) 11938V
11. Fixed A/V Freeze of some HD & SD channels in Turksat, Eutelsat and so on.
12. Fixed Panic problem on ERT world and ERT Sat channels
13. Fixed no audio on Eurosport HD, and Sport HD of Eutelsat 36E TP 12111.
14. Improver stability with file playback and trick functions use
15. Add back menu item "Subtitle language" to language setup menu
16. Updated Russian, Romania
AB_9000HD_r9203
AB_9000HD_r9203DRE
[/HIDE]
Аddon для 9023
DGStation r9207
This README is for CubeRevo HD model series.
This document was approved on 3/Apr/2009 by the DGSTATION.
DGS release r9207: ( 3/Apr/2009)
7. Fixed Web interface bugs(no RCU image, 250HD didn't work Web interface, etc) and Update Web interface version
it should be downloaded usb_all_noboot.img for upgrading this function
12. Updated Russian and Czech language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
13. Updated Smartcard driver
14. Added Drag interval adjustment preciesely such as 10 sec, 30sec, 1min, 5min, 10min, 30min, 1hour in recorded files or timeshift
- Adjustment: 1. menu, 2. direct buttons only with "Recorded files" with Pg+/- on RCU.
15. Added auto restart function when panic happens
Note.
1. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one
4x6hp
SifTeam r9207
