Имиджи для AB IPBox 9000HD
Lowik
Вышла новая DGS-прошивка r10336
Image version : r10336
DB version : r9274
http://dev.dgstation.co.kr/release/cuberevo/cuberevo_r10336.080126.zip
This README is for CubeRevo HD model series.
This document was approved on 08/Aug/2009 by the DGSTATION.
DGS release r10336: ( 08/Aug/2009)
1. Add iCubeRevo function
: If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
More description is attached. The file name is "iCubeRevo_manual.pdf".
2. Add streaming player function
: Bi-directional stream transmission between STB and PC is possible.
Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
3. Add multiroom service function
: Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
4. Add M3U Player function
: M3U is a format that stores multimedia playlists.
Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: For the meantime, we didn't display subtitle without PTS or with wrong PTS.
But, at present, we support these subtitle.
6. Improve the channel navigation
: You can see the faster movement at the channel, Fav, epg list and so on.
7. Fixed incorrect aspect ratio for 4:3 channels
: For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
8. Fixed subtitle overlaping on Hotbird.
: Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
9. Fixed ttxt subtitle page at the specific pages(775~777)
: Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
10. Update russian language file by uncle fedor.
11. Update german language file by Nils.
Note.
1. When multiroom service and streaming player is running, recording and pip doesn't support.
2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
3. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
2. The timeshift function of multiroom will release on the next.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
nikomar
nikomar
SifTeam 0.3.0 r10513
Changelog DGS:
DGS release r10513: ( 21/Aug/2009)
1. Fixed a few bugs for Post-Descramble
2. Return to previous method that select subtitle language in Language settings Menu
3. Fixed some bugs for Multiroom Service.
Protocol for mutiroom service is changed from this version. So, older SW(r10427) is not compatible with this SW(r10513).
Changelog SifTeam:
SifTeam-0.3.0
From this release I add DGS Multiboot options *
From default start without check or format HardDisk (requested) **
Is possible don't start any Service at startup ***
Personalized SAMBA and NFSD config ****
Any change in panel
* Press number button which you want on RCU when start decoder.
Multiboot function supports as below style.
# 1 boot with CDKroot(NFS)
# 2 boot from USB memory stick, with internal HDD
# 3 original images as current flash memory
# 4 boot with NFS
# 5 boot from USB memory stick, but without internal HDD
# 6 boot from internal SATA HDD
# 7 boot from flash memory for another image
Default value : no.3
** Remove file:
/var/etc/.dont_format_hdd
/var/etc/.dont_check_hdd
..and return as default system
*** Make file:
/var/etc/.dont_start_samba If present, at startup don't start samba
/var/etc/.dont_start_nfsd If present, at startup don't start nfsd
/var/etc/.dont_start_httpd If present, at startup don't start httpd
/var/etc/.dont_mount_usb If present, at startup don't mount usb
/var/etc/.dont_start_vsftpd If present, at startup don't start vsftpd
**** Make directory:
/media/ENIGMA1/movie
From other decoder with enigma1 firmware (for example SifTeam Firmware)
Add this command for share disk with samba:
smbmount "//192.168.1.9/ENIGMA1" -U root -c 'mount /hdd/ -u 500 -g 100'
Add this command for share disk with nfs:
mount -t nfs -o nolock,nfsvers=2,rsize=8192,wsize=8192,proto=tcp 192.168.1.9:/media/ENIGMA1 /hdd
192.168.1.9 is IP of IPBOXHD shared disk, ..change with your IP!!
In all Sifteam Firmware is possible add this command at bottom of file /var/etc/rcS.d/S99user_start.sh
and automount at startup.
http://dreambox.sifteam.eu/index.php?dir=9000HD/r10513/
Sani0k
DGStation CubeRevo Series nlb svn10513 v1.5
WEBIF
login: root
password: relook
Image release: NLB-10513-v1.50
***** SPECIAL ONE-TIME RELEASE *****
No big developer add-ons, no full doc updates, just plain binary/emu update.
Prepared by : Dexter
Release date : Aug 21. 2009
Changes:
* updated - Based on DGStation SVN10513
* emu - updated - possible mgcamd 1.33 (soon!)
* emu - updated - IncubusCamd 0.92
* emu - updated - mg_launcher 0.3
* other - updated - streamtools
* webif - updated - dgs webif 1.38
* carddriver- updated pacco carddriver
* skins - removed old grey blue skins
* plugins - updated - favpip v2.1.3
http://rapidshare.com/files/270121908/nlb10513.zip
daniel10
official final new nlb-image
official nlb10513 image for cuberevo (9000HD)
Thanx to Dexter for helping me out in building images ...
@all please understand and accept, that I am very busy at the moment in private things...
Anyway, I saw, that Dexter forgot to include "keyupdater" ... so here´s the official final new nlb-image
WEBIF
login: root
password: relook
Image release: NLB-10513-v1.50 no limits board --> nlb.to
Prepared by : Dexter; keyupdater added by Rainman
Release date : Aug 22. 2009
Changes:
* keyupdater added
http://rapidshare.com/files/270203861/nlb10513_9000_mod_22.08.2009.zip
12ALI1974
Обновлёное ПО
nlb10513 for ipbox 9000 / update 29.08.2009
Image release: NLB-10513-v1.50 no limits board --> http://www.nlb.to/board
Prepared by : Rainman
Release date : Aug 29. 2009
Changes:
* emu - updated - mgcamd 1.33
* emu - removed - hypercamd
* emu - mbox 0.4 build 0022 with gbox-support inserted
* plugins - favpip 2.1.3 included
* keyupdater included
* many thanx to lareq for the good cooperation in changing scripts and building image
Добавлено через 1 минуту
вот сылка
http://www.minicat.tv/board/index.php?showtopic=29419&pid=83828&st=0&#entry83828
nikomar
SifTeam 0.3.0 r11102 For Ipbox
DGS release r11102:
1. Improved sync of dvb-subtitle .
- if correct PTS from the stream, no problem
But if wrong or missing PTS data from the stream,
it possible to time difference with A/V and subtitle.
2. Changed concept for Streaming Player function
- watching one channel, another channel streaming independantly
3. Added unicable function on LNB type of satellite
configuration menu as C, Ku, UNIV, Unicable
- Caution: At this moment ,you have to install unicable for each of tuner
because it is not supported both tuner 1,2 in one menu at the same time
4. Improved visibility of menu font
5. Small many bugs fixed
http://dreambox.sifteam.eu/index.php?dir=9000HD/r11102/&file=9000-usb_update.tar.gz
leopold75
SFaddon_9000_191009_usb_db released 19.10.2009 16:50
Download link:
Добавлено через 6 минут
AB IPBox HD/9000 released at 19.10.2009 16:49
Download link:
Release Notes:
release ABr11102: ( 19/Oct/2009)
- Improved sync of dvb-subtitle.
If correct PTS from the stream, no problem, but if wrong or missing PTS data from the stream, it possible to time difference with A/V and subtitle.
- Changed concept for Streaming Player function
- Added unicable function on LNB type of satellite configuration menu as C, Ku, UNIV, Unicable
Caution : At this moment ,you have to install unicable for each of tuner because it is not supported both tuner 1,2 in one menu at the same time
- Improved visibility of menu font
- Add Timeshift function on Multiroom Service.
Some bugs of Streaming Player and Multiroom Service are fixed
and Those functions has still a few bugs, and it takes a little more time for fixing.
- Fixed a few bugs for Post-Descramble
- Return to previous method that select subtitle language in Language settings Menu
- Fixed some bugs for Multiroom Service.
- Add iCubeRevo function
Web RCU with ipod or iphone through WiFi network.
- Add Streaming Player function
streaming to/from STB or PC
- Add Multiroom Service function
: it works between CubeRevo HD boxes with network in house
- Add M3U Player function
M3U (Moving Picture Experts Group Audio Layer 3 Uniform Resource Locator, MP3 URL) is a computer file format that stores multimedia playlists
An M3U file is a plain text file that contains the locations of one or more A/V media files that CubeRevo should play such as MPEG 2, MPEG 4, H.264. Each location is placed on a new line. The locations can be either absolute or relative local pathnames or they can be URLs. The file can also include comments, prefaced by the "#" character. In extended M3U, "#" also introduces extended M3U directives.
One common use of the M3U file format is creating a playlist file that contains a single entry pointing to a stream on the Internet.
The created file provides easy access to that stream and can be used for things like downloading from a website or for IPTV with UDP protocol.
The file is saved with the "M3U" or "m3u" filename extension.
- Improve Nordic DVB subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: it supports not only notrmal DVB subtitle, but also DVB subtitle without PTS and DVB subtitle with wrong PTS.
- Improve the channel navigation speed
- Fixed incorrect aspect ratio for 4:3 channels
- Fixed overlaping Subtitle text on the screen(Hotbird)
- Fixed specific pages(775~777) of VBI TTXT for subtitle
- Update russian language file by uncle fedor.
- Update german language file by Nils.
- Recording and PIP of Server box will not be supported during Multiroom Service and Streaming Player is running.
- A kind of CODEC, FPS(frame per second) and the Resolution when encoding the file will affect to decoding the file with our Video player.
Our Video player not support to higher resolution than 720P
So, we recommend as below conditions for working well the file with our video player.
Audio Codec : MPEG layer 1,2, MP3, AC3
if the Xvid file with the GMC and Qpel when encoding, it will not works properly. it works properly after remove GMC and Qpel
if the file is MPEG 1,2, Video player is not support to Adjusting Sync function.
Caution:
11102DRE version supported only DRE CAM modules. If you don´t use DRE CAM, do not install this version !!!!
nikomar
nlb11102 for IPBox 9000HDImage release: NLB-11102-v1.51 no limits board
visit us on http://www.nlb.to/board
Prepared by : no limits board
Release date : Oct 21, 2009
Changes:
* updated - Based on DGStation SVN11102
* emu - IncubusCamd 0.93
* emu - mbox 0.4 build 0023 (gbox support)
* emu - mgcamd 1.33 (starts by default)
* webif - updated - dgs webif 1.4.03
* plugins - updated - favpip v2.3.0
* nlbpanel included
* and some other plugins :)
* info: only cool-skin installed ... deep-blue follows l8r
http://rapidshare.com/files/295854922/nlb11102_9000.zip
