Имиджи для AB IPBox 900HD
chewbacca
Модератор "AzBox"
DGStation/Abcom CubeRevo Series nlb svn9207 v1.31
WEBIF
login: root
password: relook
Prepared by : Dexter
Release date : April 4. 2009
Changes:
* updated - Using DGStation release SVN9207
* emu - added - Hypercam 1.1
* emu - added - replace.list config for german provider support
* webif - new carddriver change between dgstation and custom driver, if issues are found.
* skins - deepblue, grey and blue updated to r9207.
http://rapidshare.com/files/217373731/nlb9207-mini.zip
nikomar
AB_900HD_r9207DRE_060409_usb_all_noboot.zip
AB_900HD_r9207_060409_usb_all_noboot.zip
1. Add russian (cyrilic) translate to latin letters for front display (thanks for Janigor for your help) 2. Fixed : Channels with nonstandard characters in name , e.g. "+" show on display as channel number only. Note 1. Files "...r9207DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!! Known issues(on going). 1. Artefact with Premiere HD channels from satellite or cable. Caution. 1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10". 2. You have to change the name of updated sw into "usb update.img" when you upgrade the sw by the USB memory stick.
http://download.abcom.sk/index.php?&direction=0&order=&directory=02 AB IPBOX HD/09 900HD_Images
АВ 9341
AB r9341 30.04.2009
Change log:
1. Added automatical services moving when PMT_PID is changed on channel.
2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
3. Fixed the bugs that doen't display TTXT on the specific page.
The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2)
5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below.
- Press “1” : Jump to 10% of the recorded file
- Press “2” : Jump to 20% of the recorded file
- Press “3” : Jump to 30% of the recorded file …………
- Press “0” : Jump to beginning of the recorded file
6. Updated Russian language.
7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later.
Files "...r9341DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!!
4x6hp
r9341 from ABCOM
DRE
non DRE
[/HIDE]
4x6hp
r9341 from DGS
nikomar
NLB9341 for all 91/900/910Image release: NLB-9341-v1.320
Release date : May 3. 2009
Changes:
* updated - Based on DGStation SVN9341
* emu - updated - Hypercam 1.03
* emu - updated - IncubugCamd 0.82
* emu - updated - mbox 0.5 Build 08
* carddriver- updated pacco carddriver 090502.
* skins - deepblue, grey and blue updated to r9341.
* plugins - updated - favpip v2.1.1
* plugins - updated - bitrate 0.0.6
* plugins - fancontrol 0.1 (change config to /var/etc/fancontrol.config to activate)
* newcs - removed cardlevel from all config files. (seems to cause problems)
http://rapidshare.com/files/228696418/nlb9341-900.zip
Koreets08
AB r9341 + аддоны
Выпущен новый софт для приемников серии AB IPBox 9xxxHD, AB r9341 от 30.4.2009 имеет новые возможности и исправления.
Перечень исправлений найдете в описании к софту. Из новых функций – добавлены более широкие возможности при проигрывании файлов с HDD. Увеличено количество скоростей проигрывания файла до 16-кратной и добавлена возможность перемещения прыжками по записи. Если нажмете некоторую из числовых кнопок проигрывание перепрыгнет на некоторый числовой промежуток в процентах, например нажатием "1" перенесетесь на 10% записи, нажатием "6" на 60% , нажатием "0" на начало.
Добавлена возможность быстрого выбора "drag интервала", т.е. величины прыжка при перемотке. Drag интервал можете установить при помощи кнопок Pg UP/Pg Down на пульте ДУ. Отобразится текущее значение интервала. Устанавливаете как сильно можете перемещаться по записи при нажатии FF/REW. Изменять установки можно в пределах от 10сек до 1 часа.
Кроме обычного SF аддона в этот раз был выпущен и "SF addon with Sifteam add..." который является SF аддоном с вложенным аддоном от Sif team.
Этот аддон предназначен в основном для AB IPBox 9000HD, для обеспечения декодирования с тюнера 2
Новые функции аддона:
- декодирование передач для записывания и PiP с обоих тюнеров
- новый WebIf CUBEREVO 1.3.3 (работает и WebTV и возможно переназначить цветные кнопки на другие плагины)
- Красная кнопка: favip plugin (переключение фаворитных каналов с epg)
- Зеленая кнопка: Sif MultiMenu с разными скриптами (напр. скачивание keys с интернета, удаление tmp записей без перезагрузки, установка IPK аддонов и плагинов из папки tmp или из интернета)
- Желтая кнопка: zoom картинки (3 варианта, Между нажатиями должно быть до 5сек, иначе все начнется сначала).
- автоматически скачиваются ключи 7 раз в сутки (настройку можно изменить в /var/etc/SifTeam/conf/crontab)
- дополнительные плагины (MultiMenu, bitrate, EPG9Kdld, favpip, fps, hddtemp,
mail, weather - погода, shoutcast – интернет радио, timeonscr – часы в углу экрана, игры - pong,sudoku,tetris)
- Установка Sif плагинов online из интернета (через Sif MultiMenu – зеленая кнопка).
Установка:
Действуйте аналогично прошивки имиджа. При использовании USB-флеш переименуйте файл на "usb_update.img"
- после установки имиджа AB r9341 достаточно установить SF addon with Sifteam...., нет необходимости перед этим устанавливать классический SF аддон
- если используете карту в приемнике, работает все включая запись с 2 тюнеров и PiP
- если используете ш**у то тут изменения:: в var/keys имеются 3 файла newcamd.list (для просмотра, для записи, для PiP), ш**г должен быть прописан во всех 3х файлах. Если речь о mgcamd, то для каждого "newcamd.list" на сервере (newcs) должен быть заведен свой логин, иначе будет банить.
Все файлы newcamd.list и newcamd.conf в var/tuxbox/config удалите.
Все это действительно и для ресивера с одним тюнером, но для этого случая лучше использовать обычный SF аддон (без Sifteam) где настраивайте ш**г только в newcamd.conf в var/tuxbox/config.
SF аддон с интегрированным Sifteam аддоном полезен в основном, если используете 2 тюнера.
Имя и пароль при установке софта root/relook. Если установите некоторый из аддонов, используется root/ipbox .
http://www.satupdate.net/clanky/72-AB-r9341-c-3042009--аддоiы.html
janigor
Эту заметку я и пререводил, правда не додумался сюда закинуть. :)
Cuberevo Series 1.0.(r9580) version
Image version : r9580
DB version : r9274
1. You??d better backup the channel list using PC Editor before
downloading the new images.
2. If your STB ??db version?? is an older version, you should download
the image with ??db.img?? like ??usb_kernel_root_db.img??
??usb_nobbot.img??
If your STB ??db version?? is the same version, you can download
the image without ??db.img?? like ??usb_kernel_root.img??.
3. If AC power is unstable or disconnected while image downloading,
pictures may not appear on the screen properly. In that case, you
should make USB download mode once more and perform downloading
the image again.
4. Please read the README file carefully before you start downloading.
1.советуем сделать бекап списка каналов при помощи писи эдитора перед прошивкой
2.если база данных ресивера устаревшая, скачайте полный образ прошивки (usb_kernel_root_db.img или usb_nobbot.img), если версия базы такая же, можно использовать сокращенный например usb_kernel_root.img
3. в случай сбоя в сети электропитания во время прошивки изображение на экране может отсутствовать. в этом случае необходимо выполнить прошивку с ЮСБ повторно.
4. прочтите ридми перед началом прошивки
lit7
DGS release r9580: ( 29/May/2009)
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 250-hd in filebrowser
6. Change hdd clean process on hddinit script
7. Syunchronized sleep Mode as power_control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update tp information Thor0.8W and Astra 19.2E
10. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Caution.
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
http://www.sat-universe.com/attachment.php?attachmentid=139522&d=1243608807
Koreets08
sifteam r9580 :download:
