Имиджи для AB IPBox 900HD
12ALI1974
SF addons for AB/DGS images-IPBox900HD
vom 19.10.09
Change log:
File desciption:
SF addon for AB IPBox 9X0HD
  • SFaddon_900_191009_usb_db.rar
    3,1 MB · Просмотры: 104
Viraje
nlb11102_900 release 24.10.2009
Image release: NLB-11102-v1.51 no limits board
visit us on http://www.nlb.to/board
Prepared by : no limits board
Release date : Oct 24, 2009
Changes:
* updated - Based on DGStation SVN11102
* fixed DGS-dhcp-bug ... quick and dirty solution, but working ;-)
* emu - IncubusCamd 0.93
* emu - mbox 0.4 build 0023 (gbox support)
* emu - mgcamd 1.33 (starts by default)
* other - updated - streamtools
* webif - updated - dgs webif 1.4.03
* plugins - updated - favpip v2.3.0
* keyupdater included
* nlbpanel included
* and some other plugins :)
* info: only cool-skin installed
known bugs:
* rec and dolby led´s are always "on" ... this minor bug will solved soon
some remark:
* we ask you to not convert your old db.dat and to use in this release ... also not by using new PCEditor 1.2.54
If you still want to use old db.dat, then rename it to db.dat.edited and copy it to /var folder and reboot ...
after reboot existing db.dat will be replaced with your db.dat.edited file ... thanx
Many thanx to beta-tester redbull301
satellite
PKT mod 6.01 Tideglo rev 0.6.0
Wersja Flash (версия во внутр.флешь )
co nowego:
-nowy domyślny wygląd BlackGlass HD thanks Father Pio
-nowy Media Center thanks Father Pio
- lista kanałów 2.11.2009 by djcrash
- nowy MountManager 0.7.0
- Spinner Selector thanks to j00zek
- wielojęzyczność
-poprawki dla drugiej głowicy - już się nie restartuje w pętli
- drobne poprawki dla głowic sharpa
Pozdrawiamy Polish Kathi Team
http://rapidshare.com/files/310257898/900_usb_all_noboot.img.bz2
Lenina
Куратор "IPBox"
nikomar
Cuberevo Series 1.0.(r11453) version
0. Changed DB structure, therefore, you have to download usb_all_noboot.img, PC editor will be supported this version of DB at soon(Thanks to JonDoe)
0.1 this image is usb_noboot.img with multiboot.cfg for original DGS images as current flash memory(number 3).
1. Changed Main Menu OSD navigation method and sorting function on channel list (All, Satellite, Provider, Favorites)
2. Supported HE-AAC audio for DVB-T, but it is not supported to TV system that does not have HDCP function at this moment.
3. Supported usb_all_noboot.img using usb memory stick in USB upgrade menu(Main menu/Installation/Software Upgrade/Upgrade via USB Sitck),
therefore, from this version, you can download new image in menu using "upgrade via USB stick" menu.
4. Added RSS reader plugin(Thanks to Kneubi)
5. Fixed artefact bug with MPEG4 HD channels, especially, Premiere HD channels from satellite or cable.
6. Fixed flushing subtitle on Thor 1.0W
7. Fixed scheduled recording bug(weekday, weekend)
8. Improved Unicable function as setting two tuner parameters in one menu
9. Improved Fastscan function for Netherland Users
10.Improved Motorized DiSEqC1.2 and USALS function
11.Improved Daylight Saving function
12.Improved displaying MHW EPG
Note.
1. Prohobited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. Caution : When encoding the file, Playback via XVID player will be affected by condition of a kind of CODEC, FPS(frame per second) and the Resolution.
And XVID player doesnЎЇt support resolution higher than 720P
therefore, we recommend as below conditions.
1) resolution : equal or under 720p
2) FPS : 24, 25 and 30 fps.
3) A/V Codec
Video Codec : XVID(Without GMC or Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MPEG layer 1,2, MP3, AC3
if XVID file has GMC or Qpel option when encoding, it will not work properly.
if the file was encoded by MPEG 1 or MPEG 2, XVID player doesnЎЇt support Adjusting Sync function and Jump forward/backward function
3. ext3 file system is slower than ext2 normally.
If you will record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function
http://www.dgstation.co.kr/new/cs_s...260282945&mode=view&code=120&category=&page=1
Добавлено через 1 час 1 минуту
SifTeam 0.3.0 r11453
http://dreambox.sifteam.eu/index.php?dir=9000HD/r11453/&file=900-usb_update.tar.gz
diasys
AB_900HD_r11453_081209_usb_all_noboot.zip
http://download.abcom.sk/index.php?...es&PHPSESSID=1173aa0c848343cca90116b251b14e62
0. Changed DB structure, therefore, you have to download usb all noboot.img, PC editor will be supported this version of DB at soon(Thanks to JonDoe)
0.1 this image is usb noboot.img with multiboot.cfg for original DGS images as current flash memory(number 3).
3. Supported usb all noboot.img using usb memory stick in USB upgrade menu(Main menu/Installation/Software Upgrade/Upgrade via USB Sitck), therefore, from this version, you can download new image in menu using "upgrade via USB stick" menu.
nikomar
nlb11453_900_usb_all_noboot_141009
Image release: NLB-11453-v2.00 no limits board
Release date : Dec 14, 2009
Changes:
* update: DGStation SVN11453
* update: incubusCamd 0.96
* update: DGS-webif
* update: favpip v2.4.0 plugin
* update: nlb-panel - v2.00
* update: sci driver ... thanx to pacco
* boot-time reduced
* removed: hypercamd
* new: added oscam ... without config ... so only basic work is done
to get started and more information we suggest to take a look on /data/oscam.start
and for sure to read some manual´s about this new cardserver
* new: red-button for zoom-function (thanx to UFM-team)
* new: yellow-button for favpip-plugin 2.40
* new: added support for 2 external readers
* info: green button can be used for nlb-panel ... same like on previous images
* info: only cool-skin installed; deepblue is under rework
http://rapidshare.com/files/320898772/nlb11453_900_usb_all_noboot_141009.zip
kasvit
Vodka v.0.0.1 for Cuberevo-Series
Many thanks to Andrea for contributing to this release!
Features
- Based on r11490
- Newcs 1.67, mgcamd-1.33 and incubus 0.96 are installed
- Own card drivers.
- Management via Remote Control
Configuration
The image specific configurations are in /var/keys /var/bin.
/var/keys : incubusCamd.conf newcamd.list newcs.xml
/var/bin : incubusCamd.sh4 mgcamd newcs
источник:
http://www.denktenk.com/modules/newbb/viewtopic.php?topic_id=10460&forum=61
скачать:
http://rapidshare.com/files/322175254/Vodka_0.0.1_900HD_usb_all_noboot.rar.html
kasvit
DGS release r11502: ( 24/Dec/2009) - Merry Christmas
1. Fixed updating channel name of subfeed problem in multifeed function
2. Adopted multifeed function in cable tuner
3. In order to avoid auto formatting of USB memory stick, Modified concept to prevent automatically achieving format under 32GB HDD or USB memory when start up
4. Upgrade version of web interface 1.4.05(thanks to Nils)
5. Fixed HE-AAC with MPEG 4 video for DVB-T tuner
6. Added ipkg function
7. Added Arabic language in menu, it will support to Arabic EPG, Subtitle, teletext as well
8. Updated Lituania language(thanks to Raimundas)
9. Update bitrate plugin 0.0.7(thanks to Kneubi)
10. And other small bugs fixed
Note.
3) A/V Codec
Caution.
ftp://dev.dgstation.co.kr/pub/cuberevo-mini/netupg/DGStation/cuberevo-mini.r11502.all_noboot.zip
