Имиджи для AB IPBox 9xxHD
janigor
Поскольку имиджи выходят обычно для всей линейки ресиверов и в них сделаны одинаковые изменения, наверное целесобразно публиковать их в одной теме.
Для уточнения моделей можно использовать таблицу:
janigor
Cuberevo Series 1.0.(r11502) version
Image version : r11502
DB version : r11255
Caution
1. You had better backup the channel list using PC Editor before downloading the new images.
2. If your STB db version is an older version, you should download the image with usb_db.img like usb_kernel_root_db.img usb_nobbot.img.
If your STB db version is the same version, you can download the image without db.img like usb_kernel_root.img.
3. If AC power is unstable or disconnected while image downloading, pictures may not appear on the screen properly. In that case, you should make USB download mode once more and perform downloading the image again.
4. Please read the README file carefully before you start downloading.
janigor
This README is for CubeRevo HD model series.
This document was approved on 24/Dec/2009 by the DGSTATION.
DGS release r11502: ( 24/Dec/2009) - Merry Christmas
1. Fixed updating channel name of subfeed problem in multifeed function
2. Adopted multifeed function in cable tuner
3. In order to avoid auto formatting of USB memory stick, Modified concept to prevent automatically achieving format under 32GB HDD or USB memory when start up
4. Upgrade version of web interface 1.4.05(thanks to Nils)
5. Fixed HE-AAC with MPEG 4 video for DVB-T tuner
6. Added ipkg function
7. Added Arabic language in menu, it will support to Arabic EPG, Subtitle, teletext as well(thanks to Yahya - ACT team )
8. Updated Lituania language(thanks to Raimundas)
9. Update bitrate plugin 0.0.7(thanks to Kneubi)
10. And other small bugs fixed
Note.
1. Prohobited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. Caution : When encoding the file, Playback via XVID player will be affected by condition of a kind of CODEC, FPS(frame per second) and the Resolution.
And XVID player doesnЎЇt support resolution higher than 720P
therefore, we recommend as below conditions.
1) resolution : equal or under 720p
2) FPS : 24, 25 and 30 fps.
3) A/V Codec
Video Codec : XVID(Without GMC or Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MPEG layer 1,2, MP3, AC3
if XVID file has GMC or Qpel option when encoding, it will not work properly.
if the file was encoded by MPEG 1 or MPEG 2, XVID player doesnЎЇt support Adjusting Sync function and Jump forward/backward function
3. ext3 file system is slower than ext2 normally.
If you will record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function
Lenina
Куратор "IPBox"
kasvit
Vodka v.0.0.2 for Cuberevo-Series
Many thanks to Andrea for contributing to this release!
Features
- Based on r11502
- Add Green button function : Start & Stop Multicas, NewCamd or CCCamd in live channel
- Add Yellow button function : Vodka Special Plugin in live channel
Configuration
The image specific configurations are in /var/keys /var/bin.
/var/keys : incubusCamd.conf newcamd.list newcs.xml
/var/bin : incubusCamd.sh4 mgcamd newcs
http://letitbit.net/download/0289.0c0ce7dd0cc6c54aec3d0a4dc/vodka_0.0.2_mini_usb_all_noboot.rar.html
Lenina
Куратор "IPBox"
Уважаемые форумчане, поздравляю вас с наступающим Новым Годом!!!
Желаю всем здоровья, успехов в учебе, на профессиональном поприще, в семье.
Всем хорошего праздничного настроения!
kasvit
PGI v0.5, Höllenbrut
PGI-7000: http://www.dreambox.info/dreamboxdb/attachment.php?attachmentid=3735
PGI-9000: http://www.dreambox.info/dreamboxdb/attachment.php?attachmentid=3732
PGI-910 : http://www.dreambox.info/dreamboxdb/attachment.php?attachmentid=3734
PGI-900 : http://www.dreambox.info/dreamboxdb/attachment.php?attachmentid=3733
PGI-91 : http://www.dreambox.info/dreamboxdb/attachment.php?attachmentid=3736
Описание от соавтора прошивки,Дяди Федора:
Прошивка PGI v0.5 (базируется на софте DGS 11577)
Особенности прошивки:
* Исправлены проблемы с фризами на каналах HD (фикс позаимствован корейцами для оф. прошивок)
* Исправлена проблема с "кваканьем" ресивера при использовании mgcamd с кодировкой Ирдето (фикс позаимствован корейцами для оф. прошивок)
* В прошивку включены NewCS 1.67RC1, mgcamd 1.33, incubusCamd 0.96 и mbox , но настроены только NewCS и mgcamd
* Для поклонников командной строки встроена полная версия busybox 1.15.13 вместе с полной историей команд
* Также влючен редактор "nano" для использования с командной строки ресивера
* Свой собственный драйвер картоприемника. Есть надежда, что в следующих версиях улучшится поддержка карт, не работающих на данный момент (Радуга, Триколор, Поверхность, Платформа)
* Улучшенный сервис веб-ТВ. Поддержка кодированных каналов и качество поточного проигрывания по сети
* Значительно уменьшено время холодного старта ресивера за счет переработки большинства скриптов официальной прошивки
* Добавлена возможность запускать скрипты по кнопке www
* Исправлены самые злостные баги и убраны или добавлены вещи, которые игнорировались корейцами много много месяцев (работа в этом направлении идет постоянно)
Общие изменения по сравнению с предыдущей версией:
* Поддержка модулей DRE CAM
* Поддержка записи по NFS, вместо HDD
* Включен mg_launcher, для тех кому он нужен (работает с mgcamd 1.33)
* Добавлено сообщение на экране при рестарте эмулятора
* Обновлен веб-интерфейс до версии 1.5
* Новые версии Busybox 1.15.3, SQLite 3.6.21, e2fsprogs 1.41.9
Изменения в главном софте/интерфейсе sbox:
* При переключении каналов теперь нет застывшего изображения предыдущего канала на экране
* Из режима таймшифт можно выйти по кнопке стоп
* Перемещение по заголовкам категорий (спутники, провайдеры) в списке каналов и таже прыжки по папкам фаворитов осуществляются кнопками PgUp / PgDn, для постраничного пролистывания списков использются кнопки "влево" и "вправо"
* Исправлено автомонтирование сетевых папок
* Исправлен баг, писавший в файл /var/mount_manager_fstab неправильную информацию
* Исправлен баг, вызывавший застревание EPG только на программе "сейчас и следующая"
* Проигрывание записанного файла можно остановить кнопкой стоп, находясь в списке записей
* Добавлен индикатор громкости для медиа-плейера
* Новая опция в меню "безопасность": можно включить или выключить запрос всех паролей
* Если у канала есть свой уровень громкости, настроенный пользователем, он корректно распознается при переключении канала и последующей регулировке громкости
* Голубая кнопка сортирует по алфавиту (и по обратному алфавиту при повторном нажатии), вместо того чтобы дублировать кнопку FAV
* Улучшения в потоковом плейере по протоколу Multicast
* Убрана сломанная опция Unicast в потоковом плейере. Те кому нужен Unicast - пользуйтесь WebTV через веб интерфейс. Там всё то же самое, только работающее. Включая просмотр одного канала на ресивере и другого через WebTV
* Можно вешать пользовательский скрипт или плагин на кнопку WWW на пульте ДУ. Скрипт запускается из файла /var/bin/www.sh
* Новая (корейская) фича в меню - "Прогноз погоды". Это бета, еще и не производства PGI, поэтому никакие жалобы не принимаются.
* Скриншоты меню OSD должны теперь работать в веб-интерфейсе
Известные проблемы:
* В режиме зума 14:9 есть проблемы при переходе с SD каналов на HD. Ведется расследование.
Источник :Здесь
ferganec
3000 Cuberevo ne katit HD910
DB version : r11255
Caution
*** скрытый текст ***
Дорогой автор выложенные иммджи хорошо но для IPBOX 910 не катят я на счет Cuberevo Series 3000 проверенно!
janigor
Ну это не ко мне, а к производителю ресиверов.
Они на своем сайте выложили эти имиджи.
Я их не ставил, но думаю это у вас ошибка какая-то.
VadimIv
Я ставил по этой ссылке на 910HD - все ОК! Ищи проблемы в качестве инета (компа). Возможно качаешь битые файлы.
Lowik
Lenina
Куратор "IPBox"
nlb11577_rc1 for IPBox 9000
Image release: NLB-11577-v2.01 no limits board
visit us on http://www.nlb.to/board
Prepared by : no limits board
Release date : Jan 23, 2010
Changes:
* update: DGStation SVN11577
* update: incubusCamd 0.96
* update: mgcamd 1.35
* update: DGS-webif 1.5.1
* update: favpip v2.4 plugin
* update: bitrate v0.8.8 plugin
* update: nlb-panel - v2.00
* boot-time reduced
* new: added oscam
* new: red-button for zoom-function (thanx to UFM-team)
* new: yellow-button for favpip-plugin 2.40
* new: added support for 2 external readers
* info: green button can be used for nlb-panel ... same like on previous images
* info: deepblue skin
* removed cool-skin
* new: added mySky skin by scorpiouk (in rework) (this week via NLB-Panel fix)
static ip 192.168.1.99 is set as default for initial boot ...
sure, you can change to DHCP-mode if LAN/DHCP is connected or use another static IP
This is a rc-image (release candidate)... means it is tested and running, but can include some bugs.
Please report bugs ... thanx !
http://rapidshare.com/files/341455269/nlb11577_9000_rc1.zip - 9000
Для других моделей этой линейки пока нет.
Lowik
Новая версия прошивки DGS r11662
http://dgstation.co.kr/new/cs_softw...264766706&mode=view&code=123&category=&page=1
DB version : r11421
DGS release r11662: ( 29/Jan/2010)
1. Added Weather Forcast function
2. Added subtitle function of video player(support as *.smi)
3. Improved channel zapping time and overall response time of RCU
4. Updated bitrate plugin 0.0.8(thanks to Kneubi)
5. Updated language table
- Finnish(thanks to Christer)
- Slovak, Czech(thanks to Rene)
- Arabic(thanks to Cubebox)
6. And other small bugs fixed(thanks to pacco, kneubi)
Note.
3) A/V Codec
Caution.
Lenina
Куратор "IPBox"
ABCom_11662: 29/Jan/2010
Note.
And XVID player doesn¡¯t support resolution higher than 720P
3) A/V Codec
if the file was encoded by MPEG 1 or MPEG 2, XVID player doesn¡¯t support Adjusting Sync function and Jump forward/backward function
Caution.
Нужна регистрация.[/HIDE]
Lenina
Куратор "IPBox"
DGS_11673
1. Display black screen when change the channel
ftp://dev.dgstation.co.kr/pub/ - для всех моделей
Добавлено через 8 часов 11 минут
Vodka special v.0.0.3 -- Ipbox 9000HD
Vodka special v.0.0.3 released
2. Improved zapping speed
3. Added jump to next group function using Left/Right direction button on RCU in Favorite List
http://www.sat-universe.com/attachment.php?attachmentid=192740&d=1265114122 (21.68 MB)
