Имиджи для IPBox 910HD
АВ 9341
AB r9341 30.04.2009
Change log:
1. Added automatical services moving when PMT_PID is changed on channel.
2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
3. Fixed the bugs that doen't display TTXT on the specific page.
The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2)
5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below.
- Press “1” : Jump to 10% of the recorded file
- Press “2” : Jump to 20% of the recorded file
- Press “3” : Jump to 30% of the recorded file …………
- Press “0” : Jump to beginning of the recorded file
6. Updated Russian language.
7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later.
Files "...r9341DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!!
4x6hp
r9341 from ABCOM
DRE
non DRE
[/HIDE]
diasys
DGS release r9341: ( 1/May/2009)
This README is for CubeRevo HD model series.
This document was approved on 1/May/2009 by the DGSTATION.
1. Update trick speed in File play and live banner
Advanced : X2, X4, X8, X16 and (X1/16), (X1/, (X1/4), (X1/2)
2. ADD Proportional jump function in File play
- Press Ў°1Ў± : Jump to 10% of the recorded file
- Press Ў°2Ў± : Jump to 20% of the recorded file
- Press Ў°3Ў± : Jump to 30% of the recorded file
Ў¦Ў¦Ў¦Ў¦
- Press Ў°0Ў± : Jump to beginning of the recorded file
3. Updated Russian language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
4. support NTSC display(you can find u-boot on our homepage)
5. Update DB
6. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
7. Fixed the bugs that doen't display TTXT on the specific page.
8. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
http://www.dgstation.co.kr/new/cs_softwa…ategory=&page=1
Добавлено через 5 минут
sifteam r9341
ftp://sifteam.eu/r9341/
nikomar
NLB9341 for all 91/900/910Image release: NLB-9341-v1.320
Prepared by : Dexter
Release date : May 3. 2009
Changes:
* updated - Based on DGStation SVN9341
* emu - updated - Hypercam 1.03
* emu - updated - IncubugCamd 0.82
* emu - updated - mbox 0.5 Build 08
* carddriver- updated pacco carddriver 090502.
* skins - deepblue, grey and blue updated to r9341.
* plugins - updated - favpip v2.1.1
* plugins - updated - bitrate 0.0.6
* plugins - fancontrol 0.1 (change config to /var/etc/fancontrol.config to activate)
* newcs - removed cardlevel from all config files. (seems to cause problems)
http://rapidshare.com/files/228688148/nlb9341-910.zip
12ALI1974
nlb 9341
Lowik
DGS release r9580: ( 29/May/2009)
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 250-hd in filebrowser
6. Change hdd clean process on hddinit script
7. Syunchronized sleep Mode as power_control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update tp information Thor0.8W and Astra 19.2E
10. Fixed many small bugs
Note.
Caution.
http://dev.dgstation.co.kr/release/cuberevo-3000HD/cuberevo-3000HD_r9580.292137.zip
nikomar
AB_910HD_r9580_290509
AB_910HD_r9580_290509_usb_all_noboot.zip
1. Added automatical services moving when PMT PID is changed on channel. 2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642. 3. Fixed the bugs that doen't display TTXT on the specific page. The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V 4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2) Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2) 5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below. - Press “1” : Jump to 10% of the recorded file - Press “2” : Jump to 20% of the recorded file - Press “3” : Jump to 30% of the recorded file ………… - Press “0” : Jump to beginning of the recorded file 6. Updated Russian language. 7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later. Files "...r9341DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!
http://download.abcom.sk/index.php?...ip&directory=02 AB IPBOX HD/10 910HD_Images&
Koreets08
nlb9580_910HD_release
http://rapidshare.com/files/246705890/nlb9580_910.rar |
login: root
password: relook
Image release: NLB-9580
Prepared by : Rainman
Release date : June 20. 2009
Changes:
* updated - Based on DGStation SVN9580
* emu - updated - IncubusCamd 0.85
* emu - updated - mbox 0.6 Build 0006
* skins - only "cool" skin and "deepblue" skin included
* satangels keyupdater included
knwown bugs:
- skin "grey" and "blue" is selectable, but not included ... please do not use them
- skin "deepblue" is complete ... thanx to "Crash" for update, skin "cool" not testet
- EPG not working ... will be fixed on next update
EPG is working ... tested !
Koreets08
nlb9580_910HD_update1 "from Rainman"
UPDATE FOR 910 HD / 3000HD
DGStation/Abcom CubeRevo Series nlb svn9580
Unofficial Custom release - no limits board --> http://www.nlb.to/board
WEB-IF
login: root
password: relook
Release date : June 22. 2009
Changes:
* time-zone and EPG bug fixed
* emu - updated - IncubusCamd 0.86
* emu - updated - mbox 0.6 Build 0009
* skins "cool" set to standard; skin "deepblue" selectable (please do a reboot after chaging to this skin)
* skins "blue" and "grey" removed
http://rs627.rapidshare.com/files/247357212/nlb9580_910_update1.zip
На 910 была проблема со временем и соответственно с ЕПГ, пишет, что исправил
Lowik
Вышла новая DGS-прошивка r10336
Image version : r10336
DB version : r9274
http://dev.dgstation.co.kr/release/cuberevo-3000HD/cuberevo-3000HD_r10336.080130.zip
This document was approved on 08/Aug/2009 by the DGSTATION.
DGS release r10336: ( 08/Aug/2009)
1. Add iCubeRevo function
: If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
More description is attached. The file name is "iCubeRevo_manual.pdf".
2. Add streaming player function
: Bi-directional stream transmission between STB and PC is possible.
Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
3. Add multiroom service function
: Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
4. Add M3U Player function
: M3U is a format that stores multimedia playlists.
Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: For the meantime, we didn't display subtitle without PTS or with wrong PTS.
But, at present, we support these subtitle.
6. Improve the channel navigation
: You can see the faster movement at the channel, Fav, epg list and so on.
7. Fixed incorrect aspect ratio for 4:3 channels
: For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
8. Fixed subtitle overlaping on Hotbird.
: Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
9. Fixed ttxt subtitle page at the specific pages(775~777)
: Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
10. Update russian language file by uncle fedor.
11. Update german language file by Nils.
Note.
1. When multiroom service and streaming player is running, recording and pip doesn't support.
2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
3. ext3 file system is slower than ext2 normally.
2. The timeshift function of multiroom will release on the next.
Caution.
