Имиджи для IPBox 910HD
nikomar
SifTeam 0.3.0 r10513
Changelog DGS:
DGS release r10513: ( 21/Aug/2009)
1. Fixed a few bugs for Post-Descramble
2. Return to previous method that select subtitle language in Language settings Menu
3. Fixed some bugs for Multiroom Service.
Protocol for mutiroom service is changed from this version. So, older SW(r10427) is not compatible with this SW(r10513).
Changelog SifTeam:
SifTeam-0.3.0
From this release I add DGS Multiboot options *
From default start without check or format HardDisk (requested) **
Is possible don't start any Service at startup ***
Personalized SAMBA and NFSD config ****
Any change in panel
* Press number button which you want on RCU when start decoder.
Multiboot function supports as below style.
# 1 boot with CDKroot(NFS)
# 2 boot from USB memory stick, with internal HDD
# 3 original images as current flash memory
# 4 boot with NFS
# 5 boot from USB memory stick, but without internal HDD
# 6 boot from internal SATA HDD
# 7 boot from flash memory for another image
Default value : no.3
** Remove file:
/var/etc/.dont_format_hdd
/var/etc/.dont_check_hdd
..and return as default system
*** Make file:
/var/etc/.dont_start_samba If present, at startup don't start samba
/var/etc/.dont_start_nfsd If present, at startup don't start nfsd
/var/etc/.dont_start_httpd If present, at startup don't start httpd
/var/etc/.dont_mount_usb If present, at startup don't mount usb
/var/etc/.dont_start_vsftpd If present, at startup don't start vsftpd
**** Make directory:
/media/ENIGMA1/movie
From other decoder with enigma1 firmware (for example SifTeam Firmware)
Add this command for share disk with samba:
smbmount "//192.168.1.9/ENIGMA1" -U root -c 'mount /hdd/ -u 500 -g 100'
Add this command for share disk with nfs:
mount -t nfs -o nolock,nfsvers=2,rsize=8192,wsize=8192,proto=tcp 192.168.1.9:/media/ENIGMA1 /hdd
192.168.1.9 is IP of IPBOXHD shared disk, ..change with your IP!!
In all Sifteam Firmware is possible add this command at bottom of file /var/etc/rcS.d/S99user_start.sh
and automount at startup.
http://dreambox.sifteam.eu/index.php?dir=9000HD/r10513/
nikomar
nlb10513_910
Image release: NLB-10513-v1.50 no limits board --> http://www.nlb.to/board
Prepared by : Rainman
Release date : Aug 29. 2009
Changes:
* updated - Based on DGStation SVN10513
* emu - updated - mgcamd 1.33
* emu - updated - IncubusCamd 0.92
* emu - removed - hypercamd
* emu - mbox 0.4 build 0022 with gbox-support inserted
* other - updated - streamtools
* webif - updated - dgs webif 1.38
* skins - removed old grey blue skins
* keyupdater included
* many thanx to lareq for the good cooperation in changing scripts and building images
* thanx to giopet aud stauffie for being beta-testers
http://rapidshare.com/files/273205136/nlb10513_910.zip
SifTeam 0.3.0 r11102 For Ipbox
DGS release r11102:
1. Improved sync of dvb-subtitle .
- if correct PTS from the stream, no problem
But if wrong or missing PTS data from the stream,
it possible to time difference with A/V and subtitle.
2. Changed concept for Streaming Player function
- watching one channel, another channel streaming independantly
3. Added unicable function on LNB type of satellite
configuration menu as C, Ku, UNIV, Unicable
- Caution: At this moment ,you have to install unicable for each of tuner
because it is not supported both tuner 1,2 in one menu at the same time
4. Improved visibility of menu font
5. Small many bugs fixed
http://dreambox.sifteam.eu/index.php?dir=9000HD/r11102/&file=910-usb_update.tar.gz
12ALI1974
SF addons for AB/DGS images-IPBox910HD
vom 19.10.09
Change log:
File desciption:
SF addon for AB IPBox 9X0HD
  • SFaddon_910_191009_usb_db.rar
    3,1 MB · Просмотры: 83
Viraje
nlb11102_910 release 24.10.2009
Image release: NLB-11102-v1.51 no limits board
visit us on http://www.nlb.to/board
Prepared by : no limits board
Release date : Oct 24, 2009
Changes:
* updated - Based on DGStation SVN11102
* fixed DGS-dhcp-bug ... quick and dirty solution, but working ;-)
* emu - IncubusCamd 0.93
* emu - mbox 0.4 build 0023 (gbox support)
* emu - mgcamd 1.33 (starts by default)
* webif - updated - dgs webif 1.4.03
* plugins - updated - favpip v2.3.0
* nlbpanel included
* and some other plugins :)
* info: only cool-skin installed
known bugs:
* rec and dolby led´s are always "on" ... this minor bug will solved soon
some remark:
* we ask you to not convert your old db.dat and to use in this release ... also not by using new PCEditor 1.2.54
If you still want to use old db.dat, then rename it to db.dat.edited and copy it to /var folder and reboot ...
after reboot existing db.dat will be replaced with your db.dat.edited file ... thanx
Many thanx to beta-tester giopet
nikomar
PGI Image v0.1 for Ipbox 910HD
Features:
- Based on DGS 11102
- Newcs, Mgcamd 1.33, Incubus and Mbox are integrated but only Newcs and Mgcamd are preconfigured.
- Recent and stable Busybox 1.4.13 built in
- All shell commands are working properly and the shell has a permanent history
- Also included the editor "nano" for the console
- Own carddriver included
- DHCP boot bug is fixed
- Built in beta version of the new WebIf with support of twintuner WebIf. (thanks to Lanethe2nd)
Scrambled channels are now supported
- Improved stream quality for the Streaming Player of sbox
- Changings in bootscripts to optimize booting times.
- Scripts are on colour buttons of the RC
Changes since ver. 0.1
- Fixed bug (Box didn`t go in standby if there was no harddisk connected)
- File nonstandard_encoding moved to /var/etc to make it editable
- New streamts version with some bugfixes.
Configuration:
The image specific configuration files are located in /var/etc/boot_services.cfg
Here you can choose which services get started at bootup.
Services are for example samba, nfs, newcs, etc.
Coulor buttons:
Red: Changes emus
Green: Changes zoom
My thanks to the makers of UFM images. Some scripts and ideas are from their images.
Have fun Pacco
http://uploading.com/files/f44ae9m4/PGI-910-v0.1a.zip/
nikomar
PGI Image v0.2 for Ipbox 910HD
Hab mich mal even the problem of stuttering accepted after is not a fix to expect from DGS.
With this image, the stuttering should be on the HD channels off.
The coarser pixelated dropouts when Cinemascope films, unfortunately, not yet dissolved.
Features
- Based on GSA 11,102
- Newcs, mgcamd-1.33, incubus and mbox are installed, but are pre-configured only newcs and mgcamd.
- News busybox stable 1.4.13 installed.
The shell commands so that all the work, and the shell has a continuous history.
Moreover, the text editor nano is still attached to the console.
- Own card drivers.
- DHCP boot-bug is fixed.
- Beta version of the WebIF installed with support for TwinTuner WebTv (Thanks LaneThe2nd!)
- Streaming Player sbox fixed (server part):
Works better with encrypted channels, the quality of the stream.
- Changes to shorten boot scripts at boot time
- Color keys covered with scripts to change emus (see below)
- And other minor changes ...
http://uploading.com/files/91287f46/PGI-910-v0.2.zip/
satellite
PKT mod 6.01 Tideglo rev 0.6.0
Wersja Flash (версия во внутр.флешь )
co nowego:
-nowy domyślny wygląd BlackGlass HD thanks Father Pio
-nowy Media Center thanks Father Pio
- lista kanałów 2.11.2009 by djcrash
- nowy MountManager 0.7.0
- Spinner Selector thanks to j00zek
- wielojęzyczność
-poprawki dla drugiej głowicy - już się nie restartuje w pętli
- drobne poprawki dla głowic sharpa
Pozdrawiamy Polish Kathi Team
wersja 9000HD
http://rapidshare.com/files/310244297/9000_usb_all_noboot.img.bz2
Wersja 910
http://rapidshare.com/files/310250951/910_usb_all_noboot.img.bz2
Wersja 900
http://rapidshare.com/files/310257898/900_usb_all_noboot.img.bz2
DGS 11426
