alan55
Ребята помогите что с этим делать??Пробовал реанимировать с помощью UltimateFlashRecovery_UFS910_rev_0.997 но после ввода :loadb a4000000; bootm a4000000/никакой реакции не происходит,флешки менял,форматировал...и проблема в том что катя не загружается, на дисплее часы и всё горит красный диод с флехи не грузится,но пишет NO Folder папки все созданы правильно. Если кто может помочь то вот лог с гипертерминала при загрузке:
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002cde60: 0x2601 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e18f0: 0x02b9 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e18f4: 0x0018 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e18f8: 0x81a4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e1900: 0xe200 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e1904: 0xbcc3 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e1908: 0xbcc3 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e190c: 0xbcc3 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002e1910: 0xe000 in
stead
Further such events for this erase block will not be printed
Old JFFS2 bitmask found at 0x002e511c
You cannot use older JFFS2 filesystems with newer kernels
jffs2_scan_eraseblock(): Node at 0x002f0000 {0x1985, 0x0003, 0x00000004) has inv
alid CRC 0xe41eb0b1 (calculated 0x21aa985e)
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f0004: 0x0004 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f0008: 0xb0b1 in
stead
jffs2_scan_inode_node(): CRC failed on node at 0x002f000c: Read 0x3a87531c, calc
ulated 0x58a2b246
Empty flash at 0x002f00e0 ends at 0x002f00f8
jffs2_scan_eraseblock(): Node at 0x002f00f8 {0x1985, 0xffff, 0xffffffff) has inv
alid CRC 0xffffffff (calculated 0x19861e00)
Empty flash at 0x002f00fc ends at 0x002f0234
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f0234: 0xffff in
stead
Empty flash at 0x002f0238 ends at 0x002f1004
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f1004: 0x0004 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f1008: 0x002f in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f100c: 0xf9b1 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f1010: 0x0001 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002f1014: 0x0243 in
stead
Empty flash at 0x002f2474 ends at 0x002f3004
jffs2_scan_inode_node(): CRC failed on node at 0x002f42c4: Read 0x9fdc4077, calc
ulated 0x99d03689
jffs2_scan_inode_node(): CRC failed on node at 0x002f4344: Read 0xe28bc7e6, calc
ulated 0xe487b118
jffs2_scan_dirent_node(): Node CRC failed on node at 0x002f4394: Read 0xbd6905c6
, calculated 0xaffd8174
Empty flash at 0x002f4784 ends at 0x002f5004
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323460: 0x0151 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323464: 0x3687 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323468: 0x038e in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0032346c: 0x0002 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323470: 0x81a4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323478: 0x0200 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0032347c: 0xcfa4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323480: 0xcfa4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00323484: 0xcfa4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0032348c: 0x010d in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00337398: 0x0884 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0033739c: 0x0135 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373a0: 0x56d3 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373a4: 0x014a in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373a8: 0x0003 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373ac: 0x81a4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373b4: 0x01cd in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373b8: 0x0067 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373bc: 0x0067 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003373c0: 0x0067 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516c4: 0x1000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516c8: 0x0b4a in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516cc: 0x63cf in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516d0: 0x029a in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516d4: 0x0020 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516d8: 0x81a4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516e0: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516e4: 0x01db in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516e8: 0x01db in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003516ec: 0x01db in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00365784: 0x0185 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00365788: 0x0b24 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0036578c: 0xe3ff in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00365790: 0x029a in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00365794: 0x0007 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00365798: 0x81a4 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003657a0: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003657a4: 0x01da in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003657a8: 0x01da in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003657ac: 0x01da in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00370000: 0x1000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00370004: 0x000c in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00370008: 0xb0b1 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00373590: 0x010b in
stead
Empty flash at 0x0037eb30 ends at 0x0037f870
Empty flash at 0x0037f874 ends at 0x0037f8a0
[ OK ]
JFFS2 warning: (183) jffs2_do_read_inode_internal: no data nodes found for ino #
17
JFFS2 notice: (183) jffs2_do_read_inode_internal: but it has children so we fake
some modes for it
27
some modes for it
28
some modes for it
29
some modes for it
30
some modes for it
35
some modes for it
290
some modes for it
291
some modes for it
295
Bringing up the loopback interface...[ OK ]
Setting up hostname...(none)
[ OK ]
some modes for it
489
some modes for it
490
some modes for it
BusyBox v1.2.1 (2007.10.12-18:30+0000) Built-in shell (ash)
/config/start.sh exists .... running /config/start.sh
Vendor: Corsair Model: Flash Voyager Rev: 0.00
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sda: 7897088 512-byte hdwr sectors (4043 MB)
sda: Write Protect is off
sda: assuming drive cache: write through
sda: unknown partition table
sd 1:0:0:0: Attached scsi removable disk sda
PARAM : boot_param_version=14
PARAM : board=stb7100ref_27
PARAM : bootdelay=1
PARAM : autoload=n
PARAM : bootargs=console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1
280 coprocessor_mem=2m@0x04000000,2m@0x04200000
PARAM : bootcmd=bootm a0040000
PARAM : stdin=serial
PARAM : stdout=serial
PARAM : stderr=serial
PARAM : ethaddr=00:1D:EC:00:ED:84
BOOT PARAM VERSION = 14
mount: Mounting none on /proc/bus/usb/ failed: Device or resource busy
mkdir: Cannot create directory `/tmp/usb': File exists
/config/start.sh: /app/modules_sys/bin/stapi_modlist_mknod.sh: 14: /app/modules_
sys: Permission denied
MODULE_INSTALL_DIR = /app/modules_sys/modules26
BIN_INSTALL_DIR = /app/modules_sys/bin
the reference tree was released on W650
stos_core: module license 'ST Microelectronics' taints kernel.
stos_core_init_module(): Initializing STOS Module
stcommon_core_init_module(): Initializing STCOMMON Module
Setting all Group priorities done
PTI Clock: Cut 3.0 detected -> setting PTI workaround clock.
TC_Ram test...
Writing...
Reading...
ok
Preproc Clock: Cut 3.0 detected -> setting Preproc clock.
stpio_core_init_module(): Initializing STPIO Module
Load module fdma [254] by insmod (pid 440)
STFDMA_ClbckMgr: task created ... Priority=99
Load module stpti4_core by insmod (pid 443)
Load module stclkrv_core by insmod (pid 445)
hdmi_i2c_init : Initializing I2CHDMI kernel Module
the adapter name is i2c-ssc-0 number 0
the adapter name is i2c-ssc-1 number 1
the adapter name is i2c-ssc-2 number 2
Checking I2C bus status..
Name = ssc clock/ssc data
Status CLK = 1, Data = 1
tmp = 8477dea8
VFD_driver_Set_Controller_Type Error VFD Driver Open Failed
VFD_driver_NumberOf_Digit Error VFD Driver Open Failed
VFD_driver_Dcram_write Error VFD Driver Open Failed
VFD_driver_Display_Light_ON Error VFD Driver Open Failed
VFD_driver_Duty_Set Error VFD Driver Open Failed
mod_lxload_init: Initializing LXLOAD kernel Module, StartAddress: 0x04200000
Load module lxload[253] by insmod (pid 467)
LXLOADER virtual io kernel address of phys 0xa4200000 = 0xa4200000
/dev/stapi/lxload
mknod -m 0660 /dev/stapi/lxload c 253 0
loading audio binlxload_open: major=253 minor=0
setting up Audio LX in NON-DEBUG mode
ary file
lxload_release: major=253 minor=0
Starting Audio LX by disabling reset
LX loaded:
Base: 0xa4200000
Last: 0xa4347284
mod_lxload_exit: Exiting LXLOAD kernel Module
The I/O memory region 0x04200000 is released successfully
Unload module lxload by rmmod (pid 476)
mod_lxload_init: Initializing LXLOAD kernel Module, StartAddress: 0x04000000
Load module lxload[253] by insmod (pid 478)
LXLOADER virtual io kernel address of phys 0xa4000000 = 0xa4000000
/dev/stapi/lxload
setting up LX in NON-DEBUG mode
Starting video LX by disabling reset
LX loaded:
Base: 0xa4000000
Last: 0xa403403c
The I/O memory region 0x04000000 is released successfully
Unload module lxload by rmmod (pid 487)
EMBXSHM-PortClosed: with RT priority done with syscall. PID=500
EMBX EMBXSHM-PortClosed: task created ...
EMBXSHM-NewPort: with RT priority done with syscall. PID=499
EMBX EMBXSHM-NewPort: task created ...
mknod -m 0660 /dev/stapi/sti2c_ioctl c 253 0
Load module staudlx_core [252] by insmod (pid 513)
sthdmi_ioctl_init_module: Initializing STHDMI IOCTL Module
Load module sthdmi_ioctl[251] by insmod (pid 517)
mknod -m 0660 /dev/stapi/sthdmi_ioctl c 251 0
Load module stvid_ioctl[250] by insmod (pid 525)
mknod -m 0660 /dev/stapi/stvid_ioctl c 250 0
Load module stevt_ioctl [249] by insmod (pid 533)
mknod -m 0660 /dev/stapi/stevt_ioctl c 249 0
stblit_ioctl_init_module: Initializing STBLIT IOCTL Module
Load module stblit_ioctl[248] by insmod (pid 541)
mknod -m 0660 /dev/stapi/stblit_ioctl c 248 0
stlayer_ioctl_init_module: Initializing STLAYER kernel Module
Load module stlayer_ioctl[247] by insmod (pid 549)
mknod -m 0660 /dev/stapi/stlayer_ioctl c 247 0
Load module stpti4_ioctl [246] by insmod (pid 557)
mknod -m 0660 /dev/stapi/stpti4_ioctl c 246 0
Load module stclkrv_ioctl [245] by insmod (pid 565)
mknod -m 0660 /dev/stapi/stclkrv_ioctl c 245 0
stdenc_ioctl_init_module: Initializing STDENC IOCTL Module
Load module stdenc_ioctl[244] by insmod (pid 573)
mknod -m 0660 /dev/stapi/stdenc_ioctl c 244 0
stvtg_ioctl_init_module: Initializing STVTG IOCTL Module
Load module stvtg_ioctl[243] by insmod (pid 581)
mknod -m 0660 /dev/stapi/stvtg_ioctl c 243 0
stvout_ioctl_init_module: Initializing STVOUT IOCTL Module
Load module stvout_ioctl[242] by insmod (pid 589)
mknod -m 0660 /dev/stapi/stvout_ioctl c 242 0
stvmix_ioctl_init_module: Initializing STVMIX IOCTL Module
Load module stvmix_ioctl[241] by insmod (pid 597)
mknod -m 0660 /dev/stapi/stvmix_ioctl c 241 0
stvbi_ioctl_init_module: Initializing STVBI kernel Module
Load module stvbi_ioctl[240] by insmod (pid 605)
mknod -m 0660 /dev/stapi/stvbi_ioctl c 240 0
Load module stmerge_ioctl [239] by insmod (pid 613)
mknod -m 0660 /dev/stapi/stmerge_ioctl c 239 0
Load module staudlx_ioctl[238] by insmod (pid 621)
mknod -m 0660 /dev/stapi/staudlx_ioctl c 238 0
utils_ioctl_init_module: Initializing UTILS IOCTL Module
Load module utils_ioctl[237] by insmod (pid 629)
mknod -m 0660 /dev/stapi/utils_ioctl c 237 0
Load module stinj_ioctl [236] by insmod (pid 637)
mknod -m 0660 /dev/stapi/stinj_ioctl c 236 0
Load module stpio_ioctl [235] by insmod (pid 645)
mknod -m 0660 /dev/stapi/stpio_ioctl c 235 0
Unload module stttx_core by insmod (pid 655)
mknod: /dev/stpio_dev: File exists
mknod: /dev/vfd: File exists
CIMAX DeviceInit
SysConf device Init
LMI_SYS VCR0 = 00d40000
LMI_SYS VCR1 = 0f041000
LMI_SYS MIM0 = 057c025f
LMI_SYS MIM1 = 00000005
LMI_SYS SCR = 00000000
LMI_SYS STR = 35b06455
LMI_SYS COC = 00000000
LMI_SYS SDRA0 = 08001900
LMI_SYS SDRA1 = 08001900
LMI_SYS CIC = 00000249
LMI_SYS SDMR0 = 00000000
LMI_SYS SDMR1 = 00000000
LMI_VID VCR0 = 00d40000
LMI_VID VCR1 = 17101000
LMI_VID MIM0 = 057c025f
LMI_VID MIM1 = 00000005
LMI_VID SCR = 00000000
LMI_VID STR = 35b06455
LMI_VID COC = 00000000
LMI_VID SDRA0 = 14001900
LMI_VID SDRA1 = 14001900
LMI_VID CIC = 00000249
LMI_VID SDMR0 = 00000000
LMI_VID SDMR1 = 00000000
UFS910 Button Device Driver(by Marusys Co.)
tmp_pin = 8477dcc8
VFD_Driver Init
VFD_Controller Type : NEW Kathrein VFD
insmod: /lib/modules/2.6.17.14_stm22_0037: No such file or directory
insmod: cifs.ko: no module by that name found
tar: Short header
/config/start.sh: /config/start.sh: 47: /ramdisk/proftpd/proftpd: not found
TestModMgr::CheckTestMode CmdLine = console=ttyAS0,115200 root=/dev/mtdblock3 me
m=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
CMDLINE = console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 cop
cannot fine test mode
TestModeMgr::CheckMode : TestMode Disabled
/data/www/cgi-bin/emustarter.sh: /data/www/cgi-bin/emustarter.sh: 6: /data/www/c
gi-bin/emustop.sh: not found
eth0: 192.168.1.25/255.255.255.0 gw 192.168.1.1 dns 192.168.1.1
192.168.1.25
<br><br><br><b><center>mgcamd no start!</b><br><br><img src='../img/stop.png'></
center>
UNCOMPRESSING /config/PROPERTY_TABLE to /tmp/PROPERTY_TABLE.xml...
successfully written 2589 bytes to '/tmp/PROPERTY_TABLE.xml'!
/data/locale/language.sh: /tmp/PROPERTY_TABLE2.txt: 2: ?xml: not found
cp: /data/epg.dat: No such file or directory
/data/plugins/osd/popup.sh: kill: 4: Usage: kill [-s sigspec | -signum | -sigspe
c] [pid | job]... or
kill -l [exitstatus]
ln: /data/www/tmp: File exists
rmmod: /data/menue/interface_stapi.ko: No such file or directory
Bus error
major
BusyBox v1.2.1 (2007.10.12-18:30+0000) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe).
Options:
-m create the special file using the specified mode (default a=rw)
TYPEs include:
b: Make a block (buffered) device
c or u: Make a character (un-buffered) device
p: Make a named pipe. MAJOR and MINOR are ignored for named pipes
chmod: /dev/int_stapi: No such file or directory
Devicename = /dev/stapi/stlayer_ioctl
Set alpha
Failed to Get viewport alpha 7
current alpha = 0
Failed to set viewport alpha 7
Set black
Failed to get viewport gain 7
current black = 0
current gain = 0
Failed to set viewport gain 7
Set gain
current black = 0
current gain = 0
/data/plugins/osd/OSDshell: error while loading shared libraries: /data/lib/libf
reetype.so.6: unsupported version 0 of Verneed record
за ранее благодарен!
olegbc
SMSC: In ISR, not my interrupt, dwIntCfg=0x00000111
Господа спецы!-что ета безконечная строка в гипертерминале во время запуска реса означает-(горит кр.лампочка)-и через 5мин-30мин ресивер может загрузиться а иногда и нет!!!??? Ребятки помогите справится с проблемой!
hrustyaga
Пробывал Е2 на внешней флешке через МПИ, деактивировал и теперь
"Kathrein UFS-910" начал реанимацию:
Реанимация тюнера
1. Вставляем флешку в Катрейн (гнездо USB на передней панели)
2. Соединяем Катрейн с компьютером при помощи null модемного кабеля
3. Соединяем Катрейн с роутером и компьютером с помощью сетевого кабеля
4. Запускаем tftpd. Программа не требует конфигурации, потому что автоматически обнаружит IP нашего компьютера.
5. Запускаем программу HyperTerminal Private Edition и выбираем созданную ранее сессию
6. Сейчас включаем тюнер и немедленно жмем на клавишу ЕNТЕR клавиатуры. Сессия должна остановиться на линии STB7100-REF>
У меня в гипертарминал после enter вот это :
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
Net: VFD_Driver Init
board_version = 3
Button_value = 7
Hit any key to stop autoboot: 0
## Booting image at a0040000 ...
Image Name: Linux-2.6.17.14_stm22_0041
Image Type: SuperH Linux Kernel Image (gzip compressed)
Data Size: 1854506 Bytes = 1.8 MB
Load Address: 84001000
Entry Point: 84002000
Verifying Checksum ... OK
Starting kernel console=ttyAS0,115200 root=/dev/mtdblock3 mem=40m bigphysarea=12
80 coprocessor_mem=2m@0x04000000,2m@0x04200000 - 0x00000000 - 0 ...
и ничего не вводится ....
Добавлено через 10 часов 14 минут
получилось ) с ...цатого раза
Agent_Mulder2
Всем здрасте!
Восстановил рес по Вашему рецепту с помощью UltimateFlashRecovery_UFS910_rev_0.997. Большое спасибо.
Вопросы. Обязательно ли восстанавливать mac если это китаец?
Что поставить поверх оного, чтоб шарить? До состояния комы стоял Vit mode 1.25
crap
Всех с Новым Годом. Хочу поделиться рецептом поднятия тюнера,когда уже полная ж..па,тот случай когда горит красный индикатор на морде.Из кучи программ с форума не подходит ни одна.Никакие флешки с оффициалом,ни гипертерминал ,ни ufsconfig,ни UltimateFlashRecovery_UFS910_rev_0.997.... Нет связи с ресивером и, торба.Прочитал все сообщения с форума,и про кривые руки и ноги,думаю не всё правильно в суждениях.Люди делают всё на свой страх и риск,дайте дерзать,а не создавайте FAC как убить тюнер.У меня тюнер улетел после игры в Enigma 2,посмотрел фильм в медиацентре,выключил в дежурный режим ,а включить не смог.
Короче,из трёх версий KatyUp сработала только одна,настроил ,подключил сетевой и нульмодемный ,включил тюнер.Затем залил Dump_full_v_2_00_BETA_with_ftp из шести фалов, прогой KatyUp . Потом стандартно через флешку,можно и прогой, ufs_910_full_fw_2.02,а
уже сверху любой имидж,всё пашет.Пробуйте.
KathiUp.zip
http://sendfile.su/238382
http://depositfiles.com/ru/files/rfqu1whre
rm53
расшифровка лога загрузки
После реанимации в логе загрузки увидел неприятную информацию (в прилагаемых кусочках лога выделено красным).
Кто подскажет ответы на следующие вопросы:
1. Чтобы это значило?
2. Возможные последствия
3. Способы лечения (если есть)
Состояние тюнера после реанимации:
На внутреннюю флэш поставлена Енигма - ААФ ММЕ, через Миниубут на один из разделов флэшки поставлена Енигма от ПКТ... всё вроде работает
STMicroelectronics STb7100 Reference board initialisation
STb7100 version 3.x
Built 1 zonelists
Kernel command line: console=ttyAS0,115200 root=/dev/mtdblock3 mem=41m bigphysar
ea=2600 coprocessor_mem=2m@0x04000000,2m@0x04200000
st-coprocessor: Failed to reserve memory at 0x04000000
st-coprocessor: Failed to reserve memory at 0x04200000
STMicroelectronics - Coprocessors st231 Init
st231-0 Coprocessor -------------------------------------------
flags 0001 RAM start at 0xa4000000 size 0x00200000
cop. addr 0x04000000
Channels : Not defined
IRQ : not used
st231-1 Coprocessor -------------------------------------------
flags 0001 RAM start at 0xa4200000 size 0x00200000
cop. addr 0x04200000
IRQ : not used
TCP bic registered
TCP highspeed registered
NET: Registered protocol family 1
NET: Registered protocol family 17
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 88k freed
/etc/init.d/rcS running...
Remounting root file system in read-write mode...mount: Can't find / in /etc/fst
ab
: Success
mount: Mounting / on (null) failed: Success
[FAILED]
/etc/rcS.d/S200mountfs: /etc/rcS.d/S200mountfs: 91: cannot create /etc/mtab: Rea
d-only file system
mount: Can't find / in /etc/fstab
: Success
mushai
Народ подскажите,после прошивки на морде надпись WELCOM и ни на что больше не реагирует.плиз.
ka-igr
Ну так ВПЕРЕД, тумблером сзади выключал, флешку достал? Вообще-то как прошивал, что за прошивка?
alexeia
добрый день!Такая проблема ,перешивал катек штук 8 разных такая засада впервые:
Флешкой с оригинала 1.05 не шилась ,прошивал через гипертерминал через COM по инструкции,в итоге полная тишина и зависон. Сейчас как только гипертерминал включаю с катькой вылазит срау такой лог и не одну команду вписать нельзя! подскажите как в нём всё сначала начать
Board: STb7100-mboard
U-Boot 1.1.2 (STLINUX_2_0p1) (May 30 2007 - 16:03:49)
DRAM: 32 MB
write time out = 1, clock = 40
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
Image Name: Linux 2.6
Image Type: SH-4 Linux Kernel Image (gzip compressed)
Data Size: 1714625 Bytes = 1.6 MB
Load Address: 84401000
Entry Point: 84402000
Starting kernel console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=12
Linux version 2.6.17.14_stm22_0037 ([email protected]) (gcc version 4.1.1
(STMicroelectronics/Linux Base 4.1.1-23)) #124 PREEMPT Fri Nov 30 14:10:08 KST
2007
STb7100 version 3.x
Built 1 zonelists
Kernel command line: console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysar
PID hash table entries: 256 (order: 8, 1024 bytes)
Using tmu for system timer
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29952k/38912k available (2849k kernel code, 8948k reserved, 360k data, 8
8k init)
PVR=04061100 CVR=30480000 PRR=00009100
I-cache : n_ways=2 n_sets=256 way_incr=8192
I-cache : entry_mask=0x00001fe0 alias_mask=0x00001000 n_aliases=2
D-cache : n_ways=2 n_sets=512 way_incr=16384
D-cache : entry_mask=0x00003fe0 alias_mask=0x00003000 n_aliases=4
Mount-cache hash table entries: 512
CPU: STb710x
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
bigphysarea: Allocated 1280 pages at 0x847b1000.
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Device probe found data for platform device lirc
lirc_dev: IR Remote Control driver registered, at major 61
lirc_dev: lirc_register_plugin: sample_rate: 0
lirc_dev: lirc_register_plugin: plugin lirc_stm owner 00000000
STM LIRC plugin has IRQ 125
Lirc STM: Using IRB mode
STMicroelectronics LIRC driver configured
STPIO layer initialised
STMicroelectronics ASC driver initialized
ttyAS0 at MMIO 0xb8032000 (irq = 121) is a asc
ttyAS1 at MMIO 0xb8033000 (irq = 120) is a asc
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
s_env_mac[0] = 0
s_env_mac[1] = 0
s_env_mac[2] = :
s_env_mac[3] = 1
s_env_mac[4] = d
s_env_mac[5] = :
s_env_mac[6] = e
s_env_mac[7] = c
s_env_mac[8] = :
s_env_mac[9] = 0
s_env_mac[10] = 0
s_env_mac[11] = :
s_env_mac[12] = 8
s_env_mac[13] = 8
s_env_mac[14] = :
s_env_mac[15] = 1
s_env_mac[16] = a
get ether addr = 0, 1d, ec, 0, 88, 1a
mac hi address = 1a88, lowaddress = ec1d00
SMSC: --> init_module()
SMSC: Driver Version = 1.21
SMSC: Compiled: Aug 11 2007, 14:46:15
SMSC: Platform: ST40 STMICRO r3
SMSC: Driver Parameters
SMSC: lan_base = 0x00000000, driver will decide
SMSC: bus_width = 0, driver will autodetect
SMSC: link_mode = 0x7F, 10HD,10FD,100HD,100FD,ASYMP,SYMP,ANEG
SMSC: irq = 2
SMSC: int_deas = 0xFFFFFFFF, use platform default
SMSC: irq_pol = 1, IRQ output is active high
SMSC: irq_type = 1, IRQ output is Push-Pull driver
SMSC: rx_dma = 256, RX will use PIO
SMSC: tx_dma = 256, TX will use PIO
SMSC: dma_threshold = 200
SMSC: mac_addr_hi16 = 0x00001A88
SMSC: mac_addr_lo32 = 0x00EC1D00
SMSC: debug_mode = 0x00000007
SMSC: tx_fif_sz = 0x00050000
SMSC: afc_cfg = 0xFFFFFFFF, driver will decide
SMSC: tasklets = 0, Tasklets disabled
SMSC: phy_addr = 0xFFFFFFFF, Use internal phy
SMSC: max_throughput = 0xFFFFFFFF, Use platform default
SMSC: max_packet_count = 0xFFFFFFFF, Use platform default
SMSC: packet_cost = 0xFFFFFFFF, Use platform default
SMSC: burst_period = 0xFFFFFFFF, Use platform default
SMSC: max_work_load = 0xFFFFFFFF, Use platform default
SMSC: -->Smsc911x_init(dev=0x846E45CC)
SMSC: --> Platform_Initialize
SMSC: Lan Base at 0xA2000000
SMSC: <-- Platform_Initialize
SMSC: dwLanBase=0xA2000000
SMSC: LAN9115 identified, dwIdRev==0x01150002
SMSC: FPGA_REV == 0x00000000
SMSC: <--Smsc911x_init(), result=0
SMSC: Interface Name = "eth0"
SMSC: <-- init_module()
nwhw_config: device not found
ata1: SATA max UDMA/133 cmd 0xB9209000 ctl 0xB9209820 bmdma 0x0 irq 170
ata1: SATA link down (SStatus 0)
scsi0 : sata_stm
Generic ST boards onboard flash device: 0x01000000 (16.0Mb) at 0x00000000
Onboard_Flash: Found 1 x16 devices at 0x0 in 16-bit bank
Onboard_Flash: Found 1 x16 devices at 0x800000 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Onboard_Flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 2
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Creating 8 MTD partitions on "Onboard_Flash":
0x00000000-0x00020000 : "Boot firmware : 0xA000.0000-0xA001.FFFF"
0x00040000-0x00200000 : "Kernel - 0xA004.0000-0xA01F.FFFF"
0x00200000-0x002a0000 : "Config FS - 0xA020.0000-0xA029.FFFF"
0x002a0000-0x004e0000 : "Root FS- 0xA02A.0000-0xA04D.FFFF"
0x004e0000-0x00ae0000 : "APP_Modules 0xA04E.0000-0xA0AD.FFFF"
0x00ae0000-0x00c00000 : "EmergencyRoot 0xA0AE.0000-0xA0BF.FFFF"
0x00c00000-0x01000000 : "OtherData 0xA0C0.0000-0xA0FF.FFFF"
0x00020000-0x00040000 : "BootConfiguration 0xA002.0000-0xA003.FFFF"
ST40_start_host_control
ST40_start_host_control proceeding
ST40-ehci ST40-ehci.2: ST EHCI Host Controller
ST40-ehci ST40-ehci.2: new USB bus registered, assigned bus number 1
ST40-ehci ST40-ehci.2: irq 169, io mem 0xb91ffe00
ST40-ehci ST40-ehci.2: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: Product: ST EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.17.14_stm22_0037 ehci_hcd
usb usb1: SerialNumber: STB7100_EHCI
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver libusual
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usb 1-1: new high speed USB device using ST40-ehci and address 2
usb 1-1: Product: USB2.0 Hub
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new driver pegasus
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
stssc layer initialized
IRQ : not used
IRQ : not used
TCP bic registered
attempt to access beyond end of device
mtdblock3: rw=0, want=4612, limit=4608
UDF-fs: No VRS found
No filesystem could mount root, tried: ext3 ext2 cramfs msdos vfat iso9660 romf
s udf
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
DRAM: 32 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
2007
STb7100 version 3.x
Built 1 zonelists
8k init)
CPU: STb710x
TCP reno registered
s_env_mac[0] = 0
s_env_mac[1] = 0
s_env_mac[2] = :
s_env_mac[3] = 1
s_env_mac[4] = d
s_env_mac[5] = :
s_env_mac[6] = e
s_env_mac[7] = c
s_env_mac[8] = :
s_env_mac[9] = 0
s_env_mac[10] = 0
s_env_mac[11] = :
s_env_mac[12] = 8
s_env_mac[13] = 8
s_env_mac[14] = :
s_env_mac[15] = 1
s_env_mac[16] = a
SMSC: irq = 2
scsi0 : sata_stm
IRQ : not used
IRQ : not used
TCP bic registered
s udf
На этом месте гипертерминал стоит,катька не горит и не моргает.
allllex
тебе же по логу прямо говорится:
DRAM: 32 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
Hit any key to DRAM: 32 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
"Нажмите любую клавишу, чтобы остановить автоматический старт".
Вот в это время и нажми любую клавишу и остановишь автозагрузку и появится возможность ввода команд вручную.
alexeia
Всё уже сделал спасибо всему форуму,катька не шилась перепробовал все методы помог только этот http://forum.sat-expert.com/kathrei...shii-boks-posle-neudachnoi-pereproshivki.html после него только перешил через задний усб нужной прошивкой(передний усб не робит хотя катя из коробки)
Ещё раз спасибо всему форуму!!!
awp
реанимация
Привет, не поверите - но перелопал почти все 76 стриничек данной темы...
суть вопроса в следующем, - стояла НЕйтрино (в внутреней флеш), решил обновить паршивку и в процессе обновления тюнер повис... надпись Катрайн ...и тут понеслось... - сел вечером, спаял нульмодемный кабель и перепробовал тучи вариантов - результат "0"...
Вот лог варианта описанного на первых страничках :
DRAM:  32 MB
Flash: 16 MB
In:    serial
Out:   serial
Err:   serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
STB7100-REF> erase A0200000 A029ffff
.......... done
Erased 10 sectors
STB7100-REF> erase A02A0000 A04Dffff
.................................... done
Erased 36 sectors
STB7100-REF> erase A04E0000 A0Adffff
.................................................. done
Erased 96 sectors
STB7100-REF> erase A0C00000 A0ffffff
................................................................ done
Erased 64 sectors
STB7100-REF> setenv bootdelay 1
STB7100-REF> setenv ethaddr 0:50:fd:ff:78:ce
STB7100-REF> setenv autoload n
STB7100-REF> setenv serverip 192.168.1.100
STB7100-REF> setenv ipaddr 192.168.1.110
STB7100-REF> setenv netmask 255.255.255.0
STB7100-REF> setenv defbootargs "console=ttyAS0,115200 root=/dev/mtdblock3 mem=3
2m bigphysarea=1024 coprocessor_mem=2m@0x04000000,2m@0x04200000"
STB7100-REF> setenv bootmtd=set "bootargs ;boot"
STB7100-REF> setenv bootargs "console=ttyAS0,115200 root=/dev/mtdblock3 mem=32m
STB7100-REF> setenv filesize
STB7100-REF> setenv monitor_base
STB7100-REF> setenv monitor_len
STB7100-REF> setenv monitor_sec
STB7100-REF> setenv load_addr
STB7100-REF> setenv unprot
STB7100-REF> setenv update
STB7100-REF> setenv bootcmd bootm a0040000
STB7100-REF> saveenv
Saving Environment to Flash...
env buffer crc = 6158587f,  data = 85e0000c
Un-Protected 2 sectors
Erasing Flash...
.. done
Erased 2 sectors
Writing to Flash... .done
Protected 2 sectors
STB7100-REF>
а вот лог варианта который помог многим UltimateFlashRecovery_UFS910_rev_0.997, правда перепробовал все флехи... результата нет :( :
DRAM:  32 MB
Flash: 16 MB
In:    serial
Out:   serial
Err:   serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
STB7100-REF> loadb a4000000; bootm a4000000
## Ready for binary (kermit) download to 0xA4000000 at 115200 bps...
## Total Size      = 0x0000e5ef = 58863 Bytes
## Start Addr      = 0xA4000000
## Booting image at a4000000 ...
   Image Name:   UltimateFlashRecovery by SoLaLa
   Image Type:   SuperH Linux Standalone Program (gzip compressed)
   Data Size:    58799 Bytes = 57.4 kB
   Load Address: 85401000
   Entry Point:  85401000
   Uncompressing Standalone Application ... OK
16 MB
In:    serial
Out:   serial
Err:   serial
VFD_Driver Init
(Re)start USB...
USB:   scanning bus for devices... 3 USB Device(s) found
       scanning bus for storage devices... Device NOT ready
   Request Sense returned 00 00 00
1 Storage Device(s) found
Device NOT ready
** Can't read from device 0 **
** Unable to use usb 0:1 for fatload **
## Executing script at a4010000
Bad magic number
<INTERRUPT>
DRAM:  32 MB
Flash: 16 MB
In:    serial
Out:   serial
Err:   serial
pll0 freq 531
pll1 freq 399
board_version = 3
Button_value = 7
   Image Type:   SuperH Linux Kernel Image (unknown compression)
   Data Size:    1290554 Bytes =  1.2 MB
Unimplemented compression type 3
STB7100-REF>
что делать - как лечить ? ткните плз носом :(
Добавлено через 13 часов 1 минуту
в варианте http://forum.sat-expert.com/156946-post2.html
у меня получается
STB7100-REF> set serverip 192.168.1.110;set ipaddr 192.168.1.100;set netmask 255
.255.255.0;tftp a4100000 u986.flash;tftp a4900000 u987.flash
*** ERROR: ethaddr is not set properly!!
когда запускаю tftpd32.exe а после его в гипертерминале набираю команду
 set serverip 192.168.1.100;set ipaddr 192.168.1.110;set netmask 255.255.255.0;tftp a4100000 u986.flash;tftp a4900000 u987.flash
ничего не происходит...
у меня вин7.. и инет раздает роутер
allllex
По методу UltimateFlashRecovery_UFS910_rev_0.997 у тебя вот здесь появляется ошибка:
Устройство не готово.
Не могу прочитать файл с устройства 0
1. Возможно у тебя вставлены еще какие то флешки или USB диск. Отключи все, кроме одной флешки восстановления. Потому что программа говорит, что у тебя обнаружено 3 USB Device.
2. Если ничего не подключено, попробуй отформатировать заново флешку в FAT32, даже если думаешь, что она отформатирована.
3. Возможно также, что скачанный файл оказался битым и его не могут прочитать, попробуй перекачай.
4. Ну и последний вариант, замена флешки. Надо взять как можно старее флешку с малым объемом. Хотя бокс и увидел флешку, она не читаема, или файл на ней нечитаем.
awp
спасибо
помог ufs910_emergency-update .... был конфликт с деймоном... - убрал.. заработало и все реанимировал... ;)... буду экспериментировать дальше
МЕГА ВАЖНО ! - заменил один вдувшийся электролит (2200) в БП катьки... и все проблемы ушли в небытие. Теперь понимаю причину фиаско при попытках реанимировать через флешку... - недостаточное питания для нормальной работы USB
lagush
Друзья, посоветуйте, кто может.
Имеется Катя. При включении может гореть красная лампочка, может высветить Катрейн 910, может даже написать надпись на экранчике Starten...
Но на этом висяк.
В последнем случае, лог через терминал стопорится со строчками:
Starten...
Load module fdma [254] by insmod (pid 116)
Load module stpti4_core by insmod (pid 118)
Load module stclkrv_core by insmod (pid 119)
Через флешку прошить себя не дает. Правда, один разок через лог было видно, что типа имидж прошивается, но на экране при этом надписи UPDATE не было.
Блок питания на вид нормальный, напряжения под нагрузкой в норме, вздутых литов нет.
А вот на самой плате, два кондера по питанию 2200х10 чуток вздутые.
betina
lagush,
Обратите особое внимание на кондеры, которые находятся на блоке питания, а особенно на емкости 4700 и 3300. С вашими симптомами как раз был мой рес, как раз помогла перепайка этих двух емкостей, но у меня на 4700 вверху появилась чернота. То что Вы пишите, что напряжение нормальное, может быть совсем небольшое отклонение и этого будет достаточно, для того, что рес не будет загружаться.Их можно перепаять и самому. А вот две емкости на материнской плате, о которых Вы пишите, то если с паяльником не очень дружите, лучше самому не паять.
lagush
Кондеры на материнке перепаял. Впрочем, опыт ремонтов Катрейнов показывает, что тюнер может нормально работать и со вздутыми.
Кондеры в БП на 3300 и 4700 (90% неисправностей БП) не вздутые, напруги под нагрузкой в норме. Поэтому их не менял.
Почему загрузка прекращается на этом месте:
Starten...
Что это за устройства?
На исправной Кате в логе идет еще третье устройство:
Интересно, что если вставить флешку и включить тюнер, то лог получается чуток длиннее:
<5> Vendor: JetFlash Model: Transcend 2GB Rev: 8.07
SCSI device sda: 3944448 512-byte hdwr sectors (2020 MB)
sda: sda1
Т.е видно, что определилась моя флешка JetFlash, но на этом висяк...
А на дисплее вечно горит надпись Starten...
dortmundez
конденцаторы и нагрузка ничего общего
конденцаторы служат для фильтрации напряженя
(то есть для сглаживания пульсаций)
так что продолжай менять или для пробы можно под паять поралельно но тут как раз важно величина напряжения
иногда бывает конденцатор имеет утечку (превращается в сопротивление) и подсаживает напряжение
