Ребята, кто поможет? Катя оригинал, имидж AAF 2.0d_vitgraf.
в папке data/emu 4 файла: emustop, mgcamd, pl2303, usbserial.
в папке data/keys (по рекомендации провайдера) только два файла: mewcamd.list и mg_cfg.
newcamd.list вот такой:
CWS_KEEPALIVE = 300
CWS_INCOMING_PORT = 12000
#CWS_MULTIPLE = localhost 10110:10111 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 wan
#CWS = localhost 10110 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan
CWS = xxxxxxx.xxxxxxxx.com yyyy zzzzzzzzzz zzzzzzz 01 02 03 04 05 06 07 08 09 10 11 12 14 15 wan ntv525
CWS = xxxxxxx.xxxxxxxx.com yyyy zzzzzzzzzz zzzzzzz 01 02 03 04 05 06 07 08 09 10 11 12 14 15 wan ntvhd525
CWS = xxxxxxx.xxxxxxxx.com yyyy zzzzz zzzz 01 02 03 04 05 06 07 08 09 10 11 13 12 14 wan cyfra525
(три последние строчки - моего провайдера для +++, +++HD и ци--ы+. Под иксами адрес, под игрек порты,под зетами логины и пароли),
mg_cfg такой:
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 00 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
U: { 01 }
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
G: { 05 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 07 } 5 30
# network ecm timeout in seconds
K: { 05 }
# newcamd dead routes connect retry, sec
Q: { 5 }
# network shares priority
# 00 gbox, newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd, gbox
# 02 newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 } username password
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 03 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 03 } 172.16.1.1 28007 /tmp/mgcamd.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 15 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E
time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 07 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
B: { 00 }
Ци--а+ почти вся нормально открывается(1-3 сек), а +++ половина каналов нормально (1-3 сек.) в том числе все HD, каналов 25 открывает за 5-7сек, еще около 20 каналов открывает очень долго(20-30сек) или вообще не открывает. Причем это не обязательно одни и те же каналы(один раз заткнется на одном, другой на другом). Правда несколько украинских не открывает никогда.
Что пробовал делать:
1. Убирал из newcamd.list неясные эти строки:
2. Оставлял там только три строчки провайдера.
3. Ставил разные mg_cfg (2 присланых провайдером и 3 отсюда, VICa и других) с разными вариантами: A:{00} и др. , G:{01} и др., Q:{600}, Q:{02} и др. и тд
4. Ставил заново эмулятор, где в папке data/emu было больше файлов ( еmu и т.д.)
5. присваивал разные права (755,777,644) вышеуказанным файликам
6. Наконец пробовал по разному конфигурировать keys папку:
SoftCam.Key
AutiRoll.Key
ignore
replace
priority
mg_cfg
newcamd.list
и в таком виде, и без SoftCam.Key и AutiRoll.Key.
Катя видит инет отлично ( internet o.k., dns ok. и т.д.), я из компа вмжу катю отлично, сервер ш--ы по телнету пингуется отлично,
а вот когда по телнету захожу в Катю и делаю лог data/emu/mgcamd тут чей то не пойму. сначало быстро пробегает много строк, а потом начинает повторятся (примерно каждые 2 сек.) примерно такая запись:
(к сожалению скопировать эту запись из телнета не умею, поэтому пишу вручную)
[newcamd] xxxxxxx.xxxxxxxx.com :yyyy problem will try to reconnect
[newcamd] connecting to xxxxxxx.xxxxxxxx.com: yyyy
[newcamd] Login to xxxxxxx.xxxxxxxx.com: yyyy as zzzzz accepted 45ms
[newcamd] card data from xxxxxxx.xxxxxxxx.com :yyyy 123ms
Userid 142 caid 100 providers 3
Idents: тута три идента (шестизначные номера)
чаще всего в записи указаны порт и логин и менно Ц---ы (каналы которой как раз открывает быстро), а иногда, пореже пробивает такая же запись с портами и логинами +++.
Провайдер говорит должно все работать, у других работает и гонит на Катю ( а я ее уже полюбил, пока не ш-----я и был на разных PKT имиджах, все было гут).
Все говорят читай, изучай. Сайт такой, что можно пол года читать. А так уже прочитал:
--Вы купили Катрайн..Что дальше?Путеводитель по форуму.
--Вопросы от новичков!!
--Имиджи (по AAF)
--Эмуляторы
--разное
Да пользую Total commander , SatchannelList Editor и начинаю осваивать KCC.
Вроде все, выдохся.
