alexcat1974
040600 наверное правильно будет.
у меня и стоит 040600 (040620 поставил в игнор)
настройка mgcamd
папка data/keys у всех файлов права 777
mg_cfg
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 00 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
# + tps SID, which pmt pid contains au pid
U: { 01 } 0x12c0
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
# 32 cccamd netclient, card list saved as /tmp/cccamd.info
# (ECM only, supported server version up to 2.1.1, later not work)
G: { 01 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 07 } 5 30
# network ecm timeout in seconds
K: { 05 }
# newcamd dead routes connect retry, sec
Q: { 300 }
# network shares priority
# 00 gbox, newcamd, cccamd, radegast, camd3 (default)
# 01 camd3, radegast, cccamd, gbox, newcamd
# 02 cccamd, newcamd, camd3, gbox, radegast
P: { 00 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 } username password
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 03 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 03 } 192.168.1.27 514
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 15 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E:) time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 00 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox/mips
# 08 stapi/kathrein
# 09 stapi/ipbox
# 11 stapi/openbox
# 12 kathrein/2.02
B: { 12 }
# map all 180x nagra caids to 1801
# default is 01
F: { 00 }
ignore.list
V: { 02 37 00 }
V: { 04 06 20 }
V: { 04 06 10 }
V: { 05 0A 00 }
V: { 05 0B 00 }
V: { 05 01 00 }
newcamd.list
CWS_KEEPALIVE = 300
CWS_INCOMING_PORT = 12000
CWS = s5.xxxxx.com 4000 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4001 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4003 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4005 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4006 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4007 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4008 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4010 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4011 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4012 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4013 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4014 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4016 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4018 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4019 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = s5.xxxxx.com 4022 alexxxxx 1234567 01 02 03 04 05 06 07 08 09 10 11 12 13 14
priority.list
V: { 04 06 00 }
V: { 03 06 00 }
V: { 02 3D 00 }
V: { 02 31 00 }
V: { 02 44 00 }
V: { 03 20 00 }
V: { 02 2c 00 }
V: { 03 25 00 }
V: { 04 27 00 }
V: { 04 24 00 }
V: { 02 4F 00 }
V: { 04 22 00 }
V: { 04 17 00 }
X: { 4A E1 }
X: { 17 02 }
X: { 18 03 }
I: { 06 52 }
I: { 00 15 }
I: { 06 54 }
I: { 00 77 }
I: { 00 78 }
I: { 00 01 }
X: { 09 0F }
X: { 01 00 }
S: { 00 68 }
S: { 33 11 }
S: { 33 15 }
в файле start.sh
сделал изменения
# OSCAM
#(sleep 15;/data/emu/oscam -c /data/keys/) &
# mgcamd
(sleep 20;/data/keys;/data/emu/mgcamd) &
даю команду в телнет
/data/emu/mgcamd -c /data/keys/
лог
tuxbox mgcamd v1.35 by mixvt (compiled Jan 20 2010 22:15:45)
[mg] Net:1:7:0:5s Show ecm:0, emm:1 Up:1 Au:0 Dir:0 Osd:no:80:0 Cache:0 Log:3:192.168.1.27:514 Reread:0
[mg] Ecm cache time: 15
Box type: openbox/stapi
Conax.Key error 2: No such file or directory
SoftCam.Key error 2: No such file or directory
AutoRoll.Key error 2: No such file or directory
[config] newcamd route = alex_sob:s5.xxxxx.com:4000
[config] newcamd route = alex_sob:s5.xxxxx.com:4001
[config] newcamd route = alex_sob:s5.xxxxx.com:4003
[config] newcamd route = alex_sob:s5.xxxxx.com:4005
[config] newcamd route = alex_sob:s5.xxxxx.com:4006
[config] newcamd route = alex_sob:s5.xxxxx.com:4007
[config] newcamd route = alex_sob:s5.xxxxx.com:4008
[config] newcamd route = alex_sob:s5.xxxxx.com:4010
[config] newcamd route = alex_sob:s5.xxxxx.com:4011
[config] newcamd route = alex_sob:s5.xxxxx.com:4012
[config] newcamd route = alex_sob:s5.xxxxx.com:4013
[config] newcamd route = alex_sob:s5.xxxxx.com:4014
[config] newcamd route = alex_sob:s5.xxxxx.com:4016
[config] newcamd route = alex_sob:s5.xxxxx.com:4018
[config] newcamd route = alex_sob:s5.xxxxx.com:4019
[config] newcamd route = alex_sob:s5.xxxxx.com:4022
newcamd keep alive: 300, incoming port: 12000
network port 12000 open: bind error 98: Address already in use
[mgcam] emm thread started
[newcamd] Connecting to s5.xxxxx.com:4000...
oscam libioctl v0.01: pti open
[mg0] service 50DD index 0 pmt pid 0 (1)
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x07D1 ProvID: 040600
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x0BB9 ProvID: 030600
[mg0] ECM: CaID: 0x5601 -> CaPID: 0x0321 ProvID: 000000
[newcamd] Can't open host s5.xxxxx.com:4000
[newcamd] Connecting to s5.xxxxx.com:4001...
[newcamd] Can't open host s5.xxxxx.com:4001
[newcamd] Connecting to s5.xxxxx.com:4003...
[mg0] network can't decode
[newcamd] Can't open host s5.xxxxx.com:4003
[newcamd] Connecting to s5.xxxxx.com:4005...
[newcamd] Can't open host s5.xxxxx.com:4005
[newcamd] Connecting to s5.xxxxx.com:4006...
[newcamd] Can't open host s5.xxxxx.com:4006
[newcamd] Connecting to s5.xxxxx.com:4007...
[newcamd] Can't open host s5.xxxxx.com:4007
[newcamd] Connecting to s5.xxxxx.com:4008...
[newcamd] Can't open host s5.xxxxx.com:4008
[newcamd] Connecting to s5.xxxxx.com:4010...
[newcamd] Can't open host s5.xxxxx.com:4010
[newcamd] Connecting to s5.xxxxx.com:4011...
[newcamd] Can't open host s5.xxxxx.com:4011
[newcamd] Connecting to s5.xxxxx.com:4012...
[newcamd] Can't open host s5.xxxxx.com:4012
[newcamd] Connecting to s5.xxxxx.com:4013...
[newcamd] Can't open host s5.xxxxx.com:4013
[newcamd] Connecting to s5.xxxxx.com:4014...
[newcamd] Can't open host s5.xxxxx.com:4014
[newcamd] Connecting to s5.xxxxx.com:4016...
[newcamd] Can't open host s5.xxxxx.com:4016
[newcamd] Connecting to s5.xxxxx.com:4018...
[newcamd] Can't open host s5.xxxxx.com:4018
[newcamd] Connecting to s5.xxxxx.com:4019...
[newcamd] Can't open host s5.xxxxx.com:4019
[newcamd] Connecting to s5.xxxxx.com:4022...
[newcamd] Can't open host s5.xxxxx.com:4022
STAPI slot set pid error 71 pid bb9
Подскажите что не так
P.S и еще что-то я смотрю DCC начал у меня часто терять соединение с "катей" приходиться каждые 3 минуты обновлять
Satti
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x1771 ProvID: 040620
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x1451 ProvID: 050A00
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x0FA1 ProvID: 050B00
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x1B59 ProvID: 050100
хорошо, лог есть, теперь надо разобраться почему не играет "музыка", дело в том что у +++ много идентов (идентификаторов провайдера), но сейчас используются 030600 для HD и 040600 для SD каналов, так вот в логе шаровик вываливает все иденты что у него есть, но я вижу идент только для HD каналов, а идент для SD каналов нет, учитывая что в логе нет идента 040600 и что у alexcat1974, нет "музыки" и по мжкамду, то я могу с некоей долей уверенности сказать что alexcat1974 подключился только к HD пакету (есть еще такие шароварни которым отдельно надо платить за HD и за SD )
alexcat1974, вот еще какая особенность, настраивать оскам (что кидать в игнор а что в приорити) надо когда в файле oscam.dvbapi ничего не прописано, так вы делаете? Выложите что у вас прописано в файле oscam.dvbapi
alexcat1974
Спасибо тебе, mgcamd разобрался когда более пристально обратил внимание на то, что он не может получить ответ от серверов, а все потому что не был прописан шлюз в настройка сети был только dns 192.168.1.1 как он вообще с компом связь имел ???
mgcamd начал показывать :).
А какие косяки получаются с mgcamd, у меня на дриме все ok.
Стоит переходить на oscam
Satti
посмотри что прописано в priority.list и ignore.list, если по плюсам то в priority.list должны быть иденты 030600 и 040600 а в ignore.list все остальные что есть у твоего шаровика - 040620, 050A00, 050B00, 000000, 050100
alexcat1974
у меня сейчас так
ignore.list
V: { 02 37 00 }
V: { 04 06 20 }
V: { 04 06 10 }
V: { 05 0A 00 }
V: { 05 0B 00 }
V: { 05 01 00 }
priority.list
V: { 04 06 00 }
V: { 03 06 00 }
V: { 02 3D 00 }
V: { 02 31 00 }
V: { 02 44 00 }
V: { 03 20 00 }
V: { 02 2c 00 }
V: { 03 25 00 }
V: { 04 27 00 }
V: { 04 24 00 }
V: { 02 4F 00 }
V: { 04 22 00 }
V: { 04 17 00 }
X: { 4A E1 }
X: { 17 02 }
X: { 18 03 }
I: { 06 52 }
I: { 00 15 }
I: { 06 54 }
I: { 00 77 }
I: { 00 78 }
I: { 00 01 }
X: { 09 0F }
X: { 01 00 }
S: { 00 68 }
S: { 33 11 }
S: { 33 15 }
сейчас обнаружил что не все кинозалы идут, допустим 20 идет все ok
21 включаю начинает идти звук секунды 2-3 потом тишина и сообщение кодированная программа
Satti
alexcat1974, в архиве настроенные конфиги на 36 градус с реплей листом, поставь, быстрей летать будет
  • Новая папка.rar
    1,8 KB · Просмотры: 83
alexcat1974
ok, СПАСИБО ТЕБЕ БОЛЬШОЕ ЗА ТВОЮ ПОМОЩЬ. Только я еще так и не понял
на некоторых каналах я включаю начинает идти звук секунды 2-3 потом тишина и сообщение кодированная программа, беру нажимаю канал выше и обратно вниз уже показывает. Это такие особенности работы Mgcamd или еще дальше мне нужно копать ?
папараци
это имя знают все ...
alexcat1974, посмотри эти параметры у себя в mg_cfg
# Повторная попытка при работе с сетью. Очень важный параметр!!!
# Можно выбрать несколько значений, просуммировав отдельные опции.
# 00 не пытаться повторить запрос
# 01 повторная попытка при каждом новом ECM
# 02 повторная попытка присоединиться к недоступному ранее серверу
# каждые Q секунд (Q дается как отдельный параметр "Q" ниже)
# 04 пробовать быстро пере-соединиться к отрубившемуся серверу:
# либо после XX ECM запросов без ответа от сервера,
# либо если нет ответа от сервера в течение YY секунд
# Числа XX и YY даются как дополнительные параметры
# Это самый важный параметр в этом файле. Рекомендую установить все опции
# 01 + 02 + 04, то есть их сумму = 07. В качестве дополнительных параметров
# XX и YY можно взять 2 запроса и 4 секунды:
N: { 07 } 2 4
# Значение в секундах для тайм-аута сетевого запроса.
# Поставим 2 секунды, так как обычно сервер должен ответить
# гораздо быстрее. Если сервер не отвечает за это время, см. предыдущий
# параметр "N".
K: { 2 }
# Пытаться коннектиться на "мертвый" сервер каждые 10 секунд.
Q: { 10 }
Satti
на вскидку трудно сказать в чем может быть причина, по видимому это особенность имиджа, а вообще совет дам - не заморачивайся с имиджами на базе официальных, чтобы были целей нервы и от просмотра получать только удовольствие залей в бокс е2 и о своих проблемах будешь вспоминать как о страшном сне, попробуй это http://forum.sat-expert.com/downloads.php?do=file&id=651 или это http://forum.sat-expert.com/downloads.php?do=file&id=662 , жалеть не будешь :)
alexcat1974
N: { 07 } 2 4
# параметр "N".
K: { 2 }
Q: { 10 }
спасибо, но что-то с этими изменениями вообще почему-то ничего не показывает :(
---------- Сообщение добавлено в 00:43 ---------- Предыдущее сообщение размещено в 00:37 ----------
Хорошо, в следующий раз так и сделаю, а то завтра (вернее уже сегодня) нужно отдать этот аппарат(знакомые попросили настроить). Так, что если че то встретимся в ветки oscam.
Еще раз спасибо, bye
roman5
По поводу вашего ньюкамд листа- если пишете больше трех- максимум пяти строчек у катерины начинается ступор (это про мод), начинает капризничать и по-тихому ... для нее известном направлении
wuwka
mgcam 1.35
Может кто паможет?
У меня Кати 910 настроен Титан 1.19 и установлен mgcam 1.35 мой пакет HD+ и Sky с Astra 19°E. В меню активирывал mgcam но все каналы темны. Немагу панять вчём дело.
вот мой лог:
[mg] Net:1:7:2:3s Show ecm:1, emm:0 Up:0 Au:0 Dir:0 Osd:no:80:0 Cache:7 Log:1:192.168.178.25:514 Reread:0
[mg] Ecm cache time: 0
Box type: stapi
[FONT=&quot]got 370 cmd 9F[/FONT]
папараци
wuwka, Ньюкамд лист создан?Не вижу обращения к нему.
Для просмотра HD-каналов с этих пакетов туннелинг должен быть отключен: в файле mg_cfg параметр F: { 00 }.
wuwka
добрий вечер,
mg_cfg параметр F: { 00 } правелний,
M: { 00 }
C: { 01 }
A: { 00 }
U: { 00 }
T: { 00 }
G: { 01 }
N: { 07 } 3 6
K: { 03 }
Q: { 10 }
P: { 02 }
S: { 00 } 80
L: { 01 } 192.168.178.25 514
E: { 36000 }
H: { 07 }
R: { 00 }
D: { 03 }
B: { 00 }
F: { 00 }
newcamd.list получил от шарера уже гатовий и лежит в var/keys
CWS = IP Port w***** ****** 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserv
CWS_CONNECT_TIMEOUT = 120
CWS_KEEPALIVE = 120
папараци
У меня
U: { 02} 0x12c0
N: { 07 } 5 15
Q: { 300 }
S: { 03 }
E: { 15 }
Какой параметр B для катрайна правильный?
В ньюкамд листе сверху такие строчки:
CWS=KEEPALIVE = 300
CWS=INCOMING_PORT = 21000
vavasha07
:stop:Вот рабочий для Е2, Катрейн 910:
M: { 01 }
C: { 01 }
A: { 00 }
U: { 01 }
T: { 00 }
G: { 01 }
N: { 01 } 5 30
K: { 07 }
Q: { 150 }
P: { 02 }
S: { 03 } 80
L: { 01 } 172.16.1.1 28007 /tmp/mgcamd.log
E: { 00 }
H: { 07 }
R: { 00 }
D: { 04 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox/mips
# 08 stapi/kathrein
# 09 stapi/ipbox
# 11 stapi/openbox
B: { 11 }
F: { 00 }
У меня работает отлично!:pardon:
wuwka
Всем Привет,
заработала после измемения mg_cfg: на В: 11
А Softcam.key воще нужна в var/keys? одни пишут нада, другие нет.
Агромное Спасибо!!!
vavasha07
:snooks:Смотря какие спутники, соответсвенно каналы Вы собираетесь смотреть, если только шару, то не обязательно, а если спутники на которых (практически на всех) есть закодированные каналы, то надо.:pardon:
sergejzik
Если не хочешь с эму смотреть каналы в Biss и ORF...-то не надо
