Lenina
Куратор "IPBox"
SW 1.0.(r13651) new version for CubeRevo series
This README is for CubeRevo HD model series.
This document was approved on 10/February/2010 by the Cuberevo-Digital.
Cuberevo-digital release r13651: (10/February/2010)
1. Fix - Panic when image size is too big at photo album
2. Fix - Recording & Editing at channel list and favorite list
3. Fix - Bug at youtube
4. Fix - Can't save lnb parameter at antenna settings
5. Add Tp infomation for Astra1D,3A(23.5E) as 11856,27500,Vertical,DVB-S2,5/6/QPSK
Caution
1. Back up your data of HDD except the version of r12947 software in your box
At first, you have to back up recorded file or photo, mp3 data from STB
before downloading this image if you need. This image is supported to something
different file format or data format compare with previous software image.
2. Format HDD except the version of r12947 software in your box
You should be format HDD after downloading completed this new image,
otherwise, it will be possible to malfunction about PVR, timeshift, mp3,photo album and so on
Note.
1. Prohibited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. ext3 file system is slower than ext2 normally.
If you will record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
if you want multiboot function, download attached multiboot-XXXX.img.
Then press number button which you want on RCU when start up from shutdown.
Multiboot function supports as below style.
# 1 boot with CDKroot(NFS)
# 2 boot from USB memory stick, with internal HDD
# 3 original images as current flash memory
# 4 boot with NFS
# 5 boot from USB memory stick, but without internal HDD
# 6 boot from internal SATA HDD
# 7 boot from flash memory for another image
Default value : no.3
http://www.cuberevo.com/
Добавлено через 18 часов 0 минут
SifTeam-0.6.6-r13651-Extended (Flash - Usb)
1) New Skin Extended fixed (per accedere all'elenco delle registrazioni non é piu' necessario premere il tasto due volte)
2) Default Multiboot SDB1_2_3_4
3) Memory Settings customized
4) SifPanel customized for epg management
5) BootLogo customized
FLASH VERSION
IPbox 9000 HD - r13651-9000-extended http://www.sifteam.eu/download/deco.../ipbox-9000-hd/5622-r13651-9000-extended.html
IPbox 910 HD - r13651-910-extended http://www.sifteam.eu/download/decoder/ipbox/ipbox-910-hd/ipbox-910-hd/5623-r13651-910-extended.html
IPbox 900 HD - r13651-900-extended http://www.sifteam.eu/download/decoder/ipbox/ipbox-900-hd/ipbox-900-hd/5624-r13651-900-extended.html
IPbox 91 HD - r13651-91-extended http://www.sifteam.eu/download/decoder/ipbox/ipbox-91-hd/ipbox-91-hd/5625-r13651-91-extended.html
USB VERSION
IPbox 9000 HD - r13651-9000-extended-UsbVersion http://www.sifteam.eu/download/deco...-hd/5626-r13651-9000-extended-usbversion.html
IPbox 910 HD - r13651-910-extended-UsbVersion http://www.sifteam.eu/download/deco...0-hd/5627-r13651-910-extended-usbversion.html
IPbox 900 HD - r13651-900-extended-UsbVersion http://www.sifteam.eu/download/deco...0-hd/5628-r13651-900-extended-usbversion.html
IPbox 91 HD - R13651-91-extended-UsbVersion http://www.sifteam.eu/download/deco...91-hd/5629-r13651-91-extended-usbversion.html
Lenina
Куратор "IPBox"
BMT image 1.0 NESSIE - on CRi 13651
CUBEREVO, IPBOX 9000
This is (c) 2011 by BMTeam. All rights reserved.
BMT 1.0 NESSIE based on CRi 13651
Prepared by: BMTeam
Release date: February 12, 2011
Tested on CUBEREVO, IPBOX 9000
Contact us: [email protected]
BMTEAM IS NOT RESPONSIBLE FOR ANY DAMAGES OR HARMS CAUSED BY INSTALLATION AND OPERATION OF THIS SOFTWARE
WATCHING A PAY TV WITHOUT PAYING CORRESPONDING ABONENT FEES IS ILLEGAL AND WILL BE PUNISHED ACCORDING THE LAWS.
BY INSTALLING AND USING THE SOFTWARE YOU ACCEPT ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
-----------------Change List Since Last Release-----------------------
- fixed: timeline in epg grid
- fixed: refresh display of epg grid during scrolling (page up/down)
- fixed: refresh display of epg at fav/channel list during scrolling (page up/down)
- fixed: display of weather plugin
- fixed: emu scripts
- changed: location of the small PIP window
- added: busybox 1.18.2
- added: aspector plugin
- added: ability to disable automount "touch /var/etc/.dont_start_automount"
- added: three-step function of WWW, RED, GREEN, YELLOW and BLUE buttons
short press is 1.(first) action
longer press is 2.(second) action
the longest press is 3.(third) action
BMT defaults as below:
1. www (www.sh) - not used (can be defined by user)
2. www (www2.sh) - not used (can be defined by user)
3. www (www3.sh) - not used (can be defined by user)
1. red (red.sh) - aspector plugin
2. red (red2.sh) - not used (can be defined by user)
3. red (red3.sh) - not used (can be defined by user)
1. green (green.sh) - emuman plugin
2. green (green2.sh) - not used (can be defined by user)
3. green (green3.sh) - not used (can be defined by user)
1. yellow (yellow.sh) - bitrate plugin
2. yellow (yellow2.sh) - hddtemp plugin
3. yellow (yellow3.sh) - not used (can be defined by user)
1. blue - Instant Recording List
2. blue - Record Status (scheduled recording list)
3. blue (blue3.sh) - not used (can be defined by user)
*.sh scripts should be placed in /var/bin and attributed to executables
- added: new column with title of program in Record Status (scheduled recording list)
- added: BMT info in Status Menu
- added: reboot function at long press of power button
- added: the choice of power off/standby using short press of power button
- added: dropbear as ssh server
- added: two-step function of OK button
short press - channel/fav list
long press - epg list
- added: lynx explorer (only from console)
-----------------------IrK multiboot 3.0 options----------------------
0 = DGS - FLASH
1 = E2 - USB SDA1
2 = E2 - USB SDA2
3 = DGS - HDD SDA3
4 = E2 - FLASH
5 = E2 - HDD SDA5
6 = E2 - HDD SDA6
7 = DGS - USB SDA1
8 = E2 - USB SDB1
http://download.bmteam.pl/?&&path=images/r13651/
ivanko
http://www.bmteam.pl/---Судя по картинке-имедж на который стоило бы обратить вниммание-хороший скин -информативный телегид-даи всё на высоком уровне...
Lenina
Куратор "IPBox"
У меня с момента выхода на 9000, 910 и 900 на флешках стоят - нравятся. Но жду PGI...
doroshe
прошивка понравилась а как настроить инкубус подскажите пожал.
Lowik
Cuberevo-digital release r13736: (15/April/2010)
1. Change - ftp & telnet id : root, password : pw
2. Change - Web interface id : admin, password : pw
3. Change - First Local Time Setting - Germany
4. Chnage - TP information for HOTBIRD : 11681, 27500, Horizontal, DVB-S2, 3/4, 8PSK
12692, 27500, Horizontal, DVB-S2, 3/4, 8PSK
5. Fix - youtube doesn't work.
6. Fix - Post Descrambling bug.
7. Fix - Several bug.
http://cuberevo-digital.com/new/cs_...302861821&mode=view&code=148&category=&page=1
SifTeam
kasvit
SifTeam-0.6.7-r13736
Ссылки на загрузку с сайта SifTeamздесь
91 extended vip-file , shareflare, letitbit
91 extended USB vip-file , shareflare, letitbit
91 USB vip-file , shareflare, letitbit
910 extended vip-file , shareflare, letitbit
910 extended USB vip-file , shareflare, letitbit
910 USB vip-file , shareflare, letitbit
900 extended vip-file , shareflare, letitbit
900 extended USB vip-file , shareflare, letitbit
900 USB vip-file , shareflare, letitbit
9000 extended vip-file , shareflare, letitbit
9000 extended USB vip-file , shareflare, letitbit
9000 USB vip-file , shareflare, letitbit
Lenina
Куратор "IPBox"
Прошивка PGI 1.0
PGI v1.0, Kiryu
на основе софта CRD 13736
ВНИМАНИЕ: ПОЖАЛУЙСТА, ВНИМАТЕЛЬНО ПРОЧИТАЙТЕ ФАЙЛ README_ru.txt ДО УСТАНОВКИ ПРОШИВКИ!
Проблемы со скачиванием? Если на сайте megaupload вы выидите сообщение о том, что файл временно недоступен, просто обновите страничку (иногда нужно это сделать больше 10 раз).
Скачать прошивку для всех моделей можно отсюда: http://www.megaupload.com/?f=YYBTL48K
Для модели 100HD прошивка будет чуть позже.
Выбирайте внимательно версию для своей модели!
Для каждой модели есть 2 версии софта - обычный, для прошивки вовнутрь, и для старта с USB/HDD (имеет суффикс USB в названии файла).
Если ваш ресивер называется не IPBox (a Sezam, Cuberevo и т.д.), соответствие моделей можно увидеть здесь.
Список основных изменений в релизе PGI 1.0
Полностью переделана обработка данных ТВ Гида, теперь они хранятся в базе данных SQLite (см. README)
Поддержка EPG большего количества "нестандартных" провайдеров (см. /var/etc/epg/private_epg_info)
Улучшения в фоновом сканировании EPG, новые настройки в веб интерфейсе для сканирования EPG (см. README)
Новый индикатор ТВ Гида на инфобаннере, показывающий обработку потока данных EPG (см. README)
Переработанный список каналов: добавлено время до окончания программы, возможность просмотра названия следующей программы, информация о транспондере
Переработанный список фаворитов: название группы фаворитов в заголовке, нумерация каналов в каждой из групп начинается с 1
Один и тот же канал в нескольких фаворитных группах теперь обрабатывается правильно при переключении каналов клавишами вверх/вниз
Улучшена поддержка декодирования звука AAC
Режим соотношения сторон картинки (aspect ratio) теперь запоминается для каждого канала (см. /var/etc/ar.conf )
В Shoutcast радио добавлены закладки и скринсейвер
Название записанной программы теперь прокручивается на дисплее передней панели
Убраны ограничения конфигурации спутников, транспондеров и сканирования каналов при установленных таймерах
По списку ТВ Гида можно перескакивать клавишами вправо/влево
Любой скрипт теперь может быть назначен на цветную кнопку через веб интерфейс (см. /var/www/cgi-bin/system/plugins/scripts_addon_user.conf)
Добавлены программы для обновления DNS для сервисов DynDNS.org и no-ip.com (см. /var/bin/init.d/start.dyndns)
Добавлены утилиты scp и Midnight Commander (запустите 'mc' или 'mc -s' из Telnet) плюс полноэкранный визуальный редактор 'mcedit'
Увеличено свободное место в директории /var (ВНИМАНИЕ! НЕ ИСПОЛЬЗУЙТЕ /var для хранения данных ТВ Гида!!!)
Изменения в конфиге мультибута (см "информацию о мультибуте" в README)
Улучшения в чтении файлов M3U, теперь по-умолчанию используется файл /var/www/list.m3u, который можно редактировать самому
Фикс преждевременной остановки сканирования каналов
Фикс для сброса соотношения сторон картинки при использовании таймшифта
Фикс для одновременной записи и просмотра 2х кодированных каналов с одного и того же транспондера (включая PiP)
Фикс остановки воспроизведения записи, если запись содержала недекодированные отрезки данных
Фикс индикации времени в полосе таймшифта
Фиксы для списка записей программ: частые Epic Fail при вызове списка и невозможность удалить последнюю запись
Фикс окна передачи данных TCP, которое скорее всего вешало сеть при использовании клиента bit-torrent или при передаче данных по FTP
Фикс для кириллицы и других не-латинских алфавитов в названиях файлов, доступных через сетевые папки Windows
Фикс в коде RSS, вызывавшем Epic Fail на некоторых сайтах с кириллицей
Множество фиксов для PiP
Множество фиксов функционала PVR
Множество фиксов субтитров (остались известные проблемы с субтитрами провайдера FreeSat)
Несчетное количество самых разнообразных более мелких фиксов по улучшению стабильности
Фиксы и улучшения в коде конвертера записей
Обновлено множество сторонних библиотек и программ: busybox, e2fsprogs, sqlite, usb_modeswitch, nano, dropbear и др.
Устройства USB, доступные через /mnt/usb/sd... теперь монтируются без атрибута "sync" (см. файл /var/etc/mount.sdx1)
Из имиджа изъяты: YouTube, Multiroom, Post-Descrambling
Известные проблемы и решения некоторых из них
Вечный BOOTING? Читайте "информация о мультибуте" в README_ru.txt в архиве с прошивкой.
Не показывают закрытые каналы даже после настройки всех файлов как раньше? Читайте параграф в конце этого поста под названием "Куда делись дополнительные программы".
Не могу настроить правильно время! Правильно так: зайти в меню настроек времени, выбрать режим АВТО обновления времени, выбрать 12/24 часа. Если вы в России, то НЕ включайте летнее время, а выбирайте часовой пояс, соответствующий вашему текущему времени (Москва = GMT+4 и т.д.). Жители стран с переходом на летнее/зимнее время - включите параметр "Летнее время" и выберите правильный часовой пояс, соответствующий времени зимой (Киев = GMT+2), даты начала и конца летнего времени трогать не нужно. После выбора всех этих параметров нажмите на кнопку OK для их сохранения (не смотрите, что в этот момент время может быть неправильное!). После этого снова зайдите в меню установки времени и нажмите зеленую кнопку для получения времени со спутника. Теперь время должно показывать правильное! Больше не нажимайте OK, а просто выйдите из меню, нажав несколько раз EXIT.
Время от времени одна-две буквы в названиях каналов исчезают или заменяются на другую букву. Так же ведет себя официальная корейская прошивка. Все попытки найти истинную причину этого феномена пока что успехом не увенчались.
Иногда при вызове списка каналов (особенно в первые секунды после загрузки) ресивер выпадает в осадок - что делать? См. предыдущий вопрос.
На некоторых моделях тюнеров переход из списка LNB в настройки LNB иногда вызывает зависание ресивера - что делать? Так же ведет себя корейская прошивка. Скорее всего проблема известна, но для ее починки нужно очень многое переделать. В любом случае, это довольно редкое явление, лечащееся ребутом.
Иногда после сканирования каналов пропадает изображение и звук при переключении на канал. Корейская болезнь, лечится ребутом, жизнь в целом не портит.
Не подходят старые скины? Так и есть, ждем новых.
Не работает мой любимый плагин X? И не будет, до тех пор, пока его автор не обновит плагин для работы с новой версией софта.
Не нравится перевод интерфейса (или мой язык плохо переведен)? Свой языковой файл можно поместить сюда: /var/locale/xx/LC_MESSAGES/sbox.mo, где xx - код языка.
Информация взята с сайта разработчика https://gomel-sat.net/forums/index.php?showtopic=2089&view=findpost&p=333122
Lenina
Куратор "IPBox"
На Гомель-сате https://gomel-sat.net/forums/index.php?showtopic=2110 от дяди Федора появилась новая, достойная внимания, тема. Прошивка PGI-1.0 научилась получать ЕПГ из Интернета для каналов, в потоке которых ЕПГ отсутствует. Очень хорошая штука, я уже попробовал.
Lenina
Куратор "IPBox"
На сайте http://www.bmteam.eu/ начали выкладывать BMT_KRAKEN.
BMT 1.5 KRAKEN based on CRi 13744
Prepared by: BMTeam
Release date: May 6, 2011
Tested on CUBEREVO, IPBOX 9000, HOMECAST, XSARIUS
- fixed: blindscan and fastscan improved
- fixed: youtube buffering improved
- fixed: display/refresh EPGLIST when using RED/GREEN button (jump of more than one channel without releasing the key)
- changed: more audio/video files and variants supported in mediaplayer
- changed: three-step function of WWW, RED, GREEN, YELLOW and BLUE buttons reduced to two-step function
long press is 2.(second) action
- changed: bitrate plugin improved
- changed: hddtemp plugin improved
- changed: two-step function of OK button moved to EPG button
short press - epg grid
- changed: aspector new features
- changed: busybox modifications
- changed: kernel options optimised
- added: picons handling for channels at infobar
- added: private_aspect_info file to automatically change the aspect ratio for the selected channels (in accordance with the sender information: 16:9 or 4:3) - works only with 16:9 setting in menu
- added: in EPGLIST < and > button works as RED and GREEN buttons
- added: NTFS partitions are wittable now
...and many many more, that will be officially listed in Scylla
-------------------------------Thanks-------------------------------
- to all who help us to improve this image especially to (in alphabetical order):aftermath, genie, henia888, irk, jaro, kazetka7, kucykspeedway, mig25, schrederek, sorasil, walery.
Lenina
Куратор "IPBox"
поставил прошивку BMT не могу запустить mgcamd
У меня с первого раза тоже не получилось. Ставил на флешку. После первой установки я закидывал свои newcs.xml и newcamd.list.
Переустановил по новой и свои файлы не стал копировать, а отредактировал встроенный в прошивку newcamd.list, лишь добавив свои строки. Завелось... Но после нескольких минут просмотра ей пользоваться не стал. К хорошему быстро привыкаешь. BMT не смог пользоваться, так как уже привык к удобной настройке таймера сна и др. На BMT нет такого ЕПГ, вообще отсутствует панель скриптов, нет индивидуальных настроек (pgi.conf). Таймшифт выключается по кнопке "Воспроизведение", Аспект мне не понравился. И т.д., много мелочей, которых начинает не хватать уже после нескольких часов работы, если уже пользовался PGI. Один из плюсов - это работающий Ё-туб. Возможно еще что-то, но уже не для моего вкуса.
Lenina
Куратор "IPBox"
Cuberevo-digital release r13759: (26/May/2011)
1. fixed to erase WiFi IP information after shutdown
2. fixed to system blocked when not good network connection in youtube function
3. fixed panic in Video player sometimes when specific file playback
Caution
Note.
Здесь для всех моделей:
ftp://dev.cuberevo-digital.com/pub/
Добавлено через 19 минут
SifTeam-0.6.8-r13759 for Cuberevo
Caution
Note.
Sifteam Cheanges: (26/May/2011)
Changed the way they run the startup script.
Added the script to stop.
S "number" is run at startup
K "number" is executed at shutdown and rebooting the decoder
The controls have changed poweroffSIF and rebootSIF
In each script (boot) are required at least 10 seconds
pause (not necessarily in the script to stop)
http://forum.sifteam.eu/redirect-to...ambox.sifteam.eu/index.php?dir=9000HD/r13759/
Lenina
Куратор "IPBox"
Vodka 011 Image for Ipbox
Features
- Based on r13759
- Move to Vodka special function in My Network Setting, not in plugin menu
- Newcs 1.67, mgcamd-1.35 and oscam-1.00-unstable_svn5162-sh4-linux-stapi are installed
- Default PIN : 0000
- Web CS control in web interface, then start/stop and selection emu with color button(100HD : Yellow, others : Green) in live channel.
Configuration
/var/keys : config data as newcamd.list, newcs.xml, and oscam configuration files
/var/bin : execution files as oscam, mgcamd, newcs
900
http://www.sat-universe.com/redirec...e/1104492391/vodka011-Mini_usb_update.img.zip
910
http://www.sat-universe.com/redirec...1104489101/vodka011-3000HD_usb_update.img.zip
9000
http://www.sat-universe.com/redirec...04482044/vodka011-CubeRevo_usb_update.img.zip
wsnake
Кто ставил Vodka 011, отпишитесь плиз о багах.
Lenina
Куратор "IPBox"
Вышла PGI v1.1, Kamakiras
на основе софта CRD 13759
Список основных изменений в релизе PGI 1.1
Добавлена поддержка пиконов (см. опцию PICONS в pgi.conf)
Возможность включения таймера сна по кнопке выключения питания во время записи канала
Новая опция "Стандартный режим выключения" в настройках PVR, которая позволяет выбрать режим выключения по-умолчанию для таймеров записи
Перемотка в MP3 плейере: короткое нажатие вызывает переход на следующий/предыдущий трек, долгое нажатие вызывает перемотку с переменной скоростью при дальнейшем удерживании
Убрано ограничение на размер MP3 файлов (раньше размер был ограничен свободной памятью)
Поддержка новых пультов для модели 100HD (старый пульт можно использовать при помощи опции OLD_REMOTE в pgi.conf)
Добавлен язык Иврит
Фикс для некорректной работы с модулями CI
Фикс в мастере начальных установок (при первой загрузке ресивера с новой базой)
Фикс для проблемы с мастером начальных установок, который мог постоянно запускаться даже при существующих настройках и каналах
Фикс для отсутствующего видео/аудио после остановки таймшифта (в некоторых случаях)
Установки DiSeqC теперь сбрасываются при добавлении нового LNB конвертера для фиксированной антенны
Откорректирована ошибка в конфиге мультибута для опций USB/sda*
Исправлена проблема с удалением последней записи в списке
Фикс для проблем при выключении ресивера в момент получения данных ТВ гида
Фиксы для скриптов начальной загрузки для устройств без поддержки модулей CI
Исправлено поведение изменения аудио дорожек при просмотре записей
Фиксы и оптимизация работы ТВ гида, а также изменения по улучшению стабильности
Обновление веб интерфейса, а также библиотек SQLite, busybox и usb_modeswitch
Не нравится перевод интерфейса (или нужный вам язык плохо переведен)? Свой языковой файл можно поместить сюда: /var/locale/xx/LC_MESSAGES/sbox.mo, где xx - код языка.
Скачать и узнать подробности можно тут:
http://gomel-sat.net/forums/index.php?showtopic=2217
Lowik
Cuberevo-digital release r13787: (5/Aug/2011)
1. improved SVB-S2 8PSK signaling (STv0903 demodulator driver update)
2. fixed teletext sync problem
3. deleted menu stream plyer, m3u player and multiroom service
link
Версии от SifTeam
Augis1973
А будет новый image Vodka на основе Cuberevo-digital release r13787 с новом ему mgcamd и Newcs. Спосибо.!good!
Lenina
Куратор "IPBox"
Был в отпуске...
За это время вышли новые прошивки:
18 августа вышла в свет прошивка PGI v1.2, Moguera
Список основных изменений в релизе PGI 1.2
Изменена (оптимизирована) структура базы данных EPG, после установки прошивки нужно будет обновить данные EPG
Убрана опция 'Multi-TP' в настройках EPG через веб интерфейс, процесс получения EPG для каналов с других транспондеров теперь осуществляется автоматически (если эти данные передает провайдер)
Клавиши вправо/влево позволяют просматривать полное описание для следующей/предыдущей программы, когда нажата кнопка i в списке EPG
Исправлена проблема с выключением ресивера по длительному нажатию на кнопку питания
Исправлена проблема с перемещением каналов вверх/вниз в списке фаворитов
Исправлена проблема с навигацией в списке фаворитов (временно отсутсвующий курсор, если одна или больше групп фаворитов была удалена при помощи PC-Editor)
Исправлена проблема с получением EPG для каналов DVB-T (названия программ не отображались)
Обновлены до последних версий: FreeType, mc, iptables, usb_modeswitch а также база транспондеров
Версия базы данных каналов db.dat понижена до R13329 для совместимости с PC-Editor (все данные останутся на месте, никаких изменений в структуре!)
Полное описание и ссылки для скачивания в теме разработчика на сайте http://gomel-sat.net/forums/index.php?showtopic=2255&view=findpost&p=386697
Так же 19 августа вышла новая прошивка от DGS v13791
1. Fix - youtube doesn't work.
Скачать для всех моделей можно здесь
zinik
Как бы к ней нормал;ьный медиаплеер приделать? :pardon:
Bсем хороша, но из за медиаплеера сижу на енигме2. Интересно, а какие есть варианты прошивок для IPbox 91 с работающим медиаплеером?
Или плагин какой нибудь с плеером. У меня наружный диск подключен. Можно и плаер туда поставить поd линуkc.
