http://forum.azbox-enigma.eu/viewtopic.php?f=6&t=301
ето что за енигма??
ето что за енигма??
Текущая версия от Ripperето что за енигма??
WE WOULD LIKE TO SAY THANKS TO OPENSAT WHICH WAS INVOLVED TO PUT ALL EFFORTS TO SUPPORT AND COOPERATE ON THIS PROJECT
** Better safety while flashing Enigma 2 and new kernel versions
** Changed a way how Enigma 2 files are transferred to a AzBox HD device
** Possibility to install Enigma 2 on USB ( It install on same USB where patch.bin file is located, so there is no need to use 2 USB), and HDD.
** Fixed problem with memory space on USB ( before approx. ~50MB was needed for extracting of Image, now is not problem )
** If You install on HDD, You can turn off Format of extended partition, and Your data on HDD will stay untouched !!!
** You can Turn OFF option copy kernel, if kernel in current version is not changed
** We suggest that KERNEL is always changed, and don't touch this when You are updating to the FIRST BETA version of Enigma 2 for AzBox.
** Added DHCP Server, which will lease IP address in same range where is IP address of Your PC, ofcourse if on Your network there is not existing DHCP Server, this will help that Your AzBox HD get valid IP Address when he is in Rescue mode.
** You can list all devices which You have on network and by that way to get which IP address is from AzBox HD.
** Find IP in LAN
** For AzBox HD Ultra, model without VFD , easiest way is to use crossover cable , so directly to connect Your PC/Laptop with AzBox Ultra HD without using LAN, and with that You will be sure that DHCP which is running with AzUP will lease IP address to Your device , and You can list it by clicking on DCHP IP ?
