Кардшаринг на Kathrein UFC910
wizard.nnov.ru
сделай
ping 192.168.0.1
а так же
ping 213.177.96.1
и ещё
cat /etc/resolv.conf
Rhezus
Кстати да... про ДНС забыл... хотя если шара прописана с виде ip он не нужен...
alex1059
кто-нибудь гляньте мой лог
Kathrein UFS910 - Kernel 2.6.17.14_stm22_0037 (00:52:32).
kathrein-ufs910 login: root
Password:
BusyBox v1.2.1 (2007.10.12-18:30+0000) Built-in shell (ash)
Kathrein UFS-910 ROOTDIR
# /data/emu/mgcamd
tuxbox mgcamd v1.28 by mixvt (compiled Feb 5 2008 15:05:15)
[mg] Net:4:7:1:5s Show ecm:1, emm:1 Up:6 Au:1 Dir:0 Osd:no:80:0 Cache:7 Log:3:хх
.ххх.ххх.ххх:ххххх Reread:0
[mg] Ecm cache time: 15
Box type: stapi
Conax.Key error 2: No such file or directory
# Keys readed
ignore prov 0500:008100
ignore prov 0500:008300
ignore prov 0500:020000
ignore prov 0500:020010
ignore prov 0500:022600
ignore prov 0500:022610
ignore prov 0500:020800
ignore prov 0500:020810
ignore prov 0100:00006A
ignore prov 0100:00006C
ignore prov 0100:000080
ignore prov 0100:000086
ignore prov 0100:000084
ignore prov 0100:00003D
ignore caid 1830
ignore caid 1831
ignore caid 0D22
priority caid 0500
priority caid 1702
priority caid 1801
priority caid 090F
priority caid 0100
ecm replace 213F:0100:000202:06A7 -> 0100:000030:06A7
ecm replace 2140:0100:000202:06A8 -> 0100:000030:06A8
ecm replace 2141:0100:000202:06A9 -> 0100:000030:06A9
caid replace 1702 -> 1801
caid replace 1722 -> 1801
parse error: cs357x://хххххх:пароль@ххх.ххх.ххх.ххх:ххххх@0500:020710&0500:023100
&0500:024700&090F:000000
[mgcam] emm thread started
[mgcamd] tps update started.
[mg0] service 283D index 0 pmt pid 0 (1)
ECM: CaID: 0x0500 -> CaPID: 0x1771 ProvID: 020710
ECM: CaID: 0x0500 -> CaPID: 0x0FA1 ProvID: 023700
ECM: CaID: 0x0500 -> CaPID: 0x0BB9 ProvID: 030600
[mg0] No viaccess key(s) found for id 20710 keynr 08
[mg0] network can't decode
[mg0] pid 0x1771 failed to decode.
[mg0] No viaccess key(s) found for id 23700 keynr 08
[mg0] pid 0x0FA1 failed to decode.
/data/keys/tps.au error 2: No such file or directory
[mg0] No viaccess key(s) found for id 30600 keynr 06
[mg0] pid 0x0BB9 failed to decode.
[mgcamd] emm started
EMM: CaID: 0x0500 -> CaPID: 0x03EA ProvID: 020710
EMM: CaID: 0x0500 -> CaPID: 0x03E8 ProvID: 023700
EMM: CaID: 0x0500 -> CaPID: 0x03EB ProvID: 030600
[mgcamd] emm stopped
На экране малевич. Подскажите где грабли.
oleg1981
parse error: cs357x://хххххх:пароль@ххх.ххх.ххх.ххх:ххххх@0500:020710&05 00:023100
Пишет что ошибка в конфиге в camd3.serwers.Для каждого идента нужно прописать отдельную строку:
cs357x://логин:пароль@айпи:порт?090F:000000=090F:000000
cs357x://логин:пароль@айпи:порт?0500:024700=0500:024700
это две строки для виасат и каналов на амосе,дальше по примеру пропиши сам.Но вообщето если пользуешся шарингом по протоколу cs357,то лучше уж пользоватся родным для него ему камд3,тем более он на катрейне реализован.
alex1059
Все, заработало!!!!!
Всем спасибо, кто помогал. Пришлось поставить эмулятор камд3. На мжкамде запустить шару по протоколу камд3 не удалось. А на камд3 запустилось с полпинка.
alex1059
Кто немецкий знает? Переведите
W A R N I N G
Fehler bei Download!
IP-Einstellungen pruefen
oder der Server ist ueberlastet!
alex1059
Вообще непонятка какая то. Теперь эмулятор камд3 не запускается. Сношу его вообще из тюнера и устанавливаю мжкамд, все нормально. Потом сношу мжкамд и устанавливаю камд3, он не хочет стартовать. Тюнер перезагружаю, права присваиваю. что дальше делать не знаю. Извиняюсь что в этой ветке, но из-за этого не работает шаринг.
вообще-то у кого-то шара по протоколу камд3 работает на эмуляторе мжкамд?
Все, уже сил никаких нету. Перешил тюнер(имижд бай краш). Установил эму камд3. Настроил шару. Радовался ровно пол часа. Эмулятор завис и теперь не только шары нет, но и други е каналы, которые открывало эму не открываются. Шара по протоколу камд3, может она каким-то образом тормозит эму, или надо какие-то еще файлы выкидывать. Спецы помогайте.
Установил эму мжкамд. Эму запустилось. Каналы которые оно должно открывать открылись. А шара не идет. Кидаю лог гляньте.
Kathrein UFS910 - Kernel 2.6.17.14_stm22_0037 (16:50:32).
Password:
# data/emu/mgcamd
tuxbox mgcamd v1.29a by mixvt (compiled Feb 17 2008 16:10:16)
[mg] Net:5:7:1:5s Show ecm:1, emm:1 Up:5 Au:1 Dir:0 Osd:no:80:0 Cache:7 Log:3:19
2.168.0.1:2000 Reread:0
Box type: stapi
# Keys readed
camd3 route хх.ххх.хх.хх:ххххх 000500:024400
camd3 route хх.ххх.хх.хх:ххххх 000500:021110
camd3 route хх.ххх.хх.хх:ххххх 000500:023B00
camd3 route хх.ххх.хх.хх:ххххх 000500:020910
camd3 route хх.ххх.хх.хх:ххххх 000500:024B00
camd3 route хх.ххх.хх.хх:ххххх 000100:000068
camd3 route хх.ххх.хх.хх:ххххх 00090F:000000
camd3 route хх.ххх.хх.хх:ххххх 000100:000065
camd3 route хх.ххх.хх.хх:ххххх 000500:024700
camd3 route хх.ххх.хх.хх:ххххх 000500:023100
camd3 route хх.ххх.хх.хх:ххххх 000500:020710
[mg0] service 780 index 0 pmt pid 0 (1)
ECM: CaID: 0x090F -> CaPID: 0x0789 ProvID: 000000
STAPI slot set pid error 71 pid 789
EMM: CaID: 0x090F -> CaPID: 0x00C0 ProvID: 000000
[mg0] camd3 route = хх.ххх.хх.хх:ххххх
camd3: wrong ucrc: got fcf98195, want 9581f9fc
и т.д.
andyX
посмотрите пож лог ..бьюсь с эму весь день
Kathrein UFS910 - Kernel 2.6.17.14_stm22_0037 (00:00:10).
Password:
# data/emu/mgcamd
[mg] Net:1:7:0:5s Show ecm:1, emm:1 Up:1 Au:2 Dir:0 Osd:no:80:0 Cache:7 Log:3:17
2.16.1.1:28007 Reread:0
Box type: stapi
# Keys readed
[mg0] service 283F index 0 pmt pid 0 (1)
ECM: CaID: 0x0500 -> CaPID: 0x1773 ProvID: 020710
ECM: CaID: 0x0500 -> CaPID: 0x0FA3 ProvID: 023700
ECM: CaID: 0x0500 -> CaPID: 0x0BBB ProvID: 030600
[mg0] pid 0x1773 failed to decode.
[mg0] pid 0x0FA3 failed to decode.
[mg0] pid 0x0BBB failed to decode.
STAPI filter set error 80 pid 1773
andyX
..не пойму где косяк..ткните пож ...шарил на компе с плагином циклона, потом юзал мобишару ...а тут никак не разберусь...
driver
Гуру
Согласно твоего лога, эмулятор не обращается к серверу. Посмотри где у тебя находится newcamd.list и правильно ли внесены все параметры сервера в нем.
andyX
прикрепил mg_cfg и newcamd list посмотрите пож что не так ...да ещё немного инфы имидж aaf 1.3 и-нет адсл pppoe
  • newcamd.list.example.txt
    92 байт · Просмотры: 127
  • mg_cfg.txt
    3,5 KB · Просмотры: 109
andyX
спасибо vic понял свою ошибку...хотя она и не совсем моя, просто в таком виде я копировал этот файл из архива с mgcamd 1.29 он там вот так и выглядет newcamd.list.example ...убрал example и всё заработало с пол тычка...ещё раз большой респект
Реакции: vic
boris6295
Если WiFi с точкой доступа и подключением к кате через сетевой разъём, то всё будет работать.
Если ты хочеш поставить сетевой адаптер WiFi в катю , то пока нет...
Получилось с точкой доступа D-Link DWL-2100ap, только надо его перевести в режим AP client.
Борис
Пробовал..что то у меня не лезёт...длинк650+..
alex1059
Я подключил сегодня к инету через BeeRouter. Это 3G роутер.
Кто-то интересовался как можно подключить катю к инету с помощью мобильного телефона или 3G модема. Это как раз то что надо.
larrych
карта N
Ущё одна идея у меня появилась :реализовать шаринг карты N польской платформы конакс...у меня связка дрим7000-Катрайн910..поскольку дрим7000 не тянет мпег4 то есть мысль разшарить её через дрим..всё равно ж валяется бездельник..
Привет Vic, получился ли у тебя шаринг этой N карты?
Мне тут удалось поднять Gbox на Кате и соответсвено вопрос, как можно через тебя купить эту карту(и с тюнером и подпиской- я в курсе, что все идет вместе и с годовой оплатой). Если что то пиши в личку.
