История изменения протокола CCcam (поможет лучше понять его возможности):
1.0.0
-first public release
-various smartcards
-various emus
-share2share support (C: and F: entry)
-newcamd support (N: entry)
-radegast support (R: entry)
-all shares are available for clients on a single port (default 12000)
-emu's can be shared one hop down only
-cards can be shared multiple hops down
-each CCcam node has a unique nodeid
-routes to a card are given with nodelists
-when a card is reachable through multiple routes, each unique route will be available as individual share
-shares with nodeid 'abc' in the routelist are never sent to client with nodeid 'abc', to avoid route loops
-watch your shares, including full routelist, on port 15002
-start with -h to view available commandline options
-syslog support, start with -v for more verbosity
-start with -d to run in foreground, and log to console instead of syslog
-inserted cards (in either available reader) start working right away
-all used config and key files are re-read on change, never need to restart CCcam
1.1.0
-camd3 support, one card per L: line
-support to add downshare limits to F: entries
1.1.1
-when a share doesn't work for a certain channel, skip aliases of that share for that channel
(aliases are the same cards shared through different routes, they have equal nodeID_shareID at the end of their line in the output on port 15002)
-ignore '0' providerids on seca cards
-nagra2 emu fix for some providers
-fixed occasional nds emm freeze
-allow multiple L: entries to connect to different cards on the same camd3 server/port
-fixed phoenix on certain comport chipsets
-optimized share protocol (backward compatibility with <1.1.1 guaranteed, warning, will be removed in next release)
1.2.0
-fixed betacrypt entitlements
-fixed betacrypt emm
-fixed nds entitlements
-fixed nds freeze with certain ecm on phoenix
-irdeto emu emm added
-seca emu added
-initialise all cards before starting to decode, ensures immediate success on startup
-restart emm when a card is inserted, for easier activation of new cards
-faster client ecm handling (new client logon no longer delays requests of existing clients)
-command-based info interface on port 16000
-web info interface on port 16001
(As of now getting info from ports 15000-15004 is deprecated. This interface will be removed in the next release.)
-newcamd stealth mode added
-removed <1.1.1 backward compatibility code from share protocol, to allow full use of optimisations introduced in 1.1.1
-when CCcam was connecting to a share it kept on connecting on same ip, not very good when a dyndns address was in the config
-ecm request cache didn't work in all situations, caching fixed and improved.
-emm didn't always work on demuxapi systems (e.g. relook, mutant). Fixed.
-WARNING: F: entry syntax changed, check and update your CCcam.cfg; added parameters to allow emusharing and emm, per client
1.2.1
-fixed smartcard support for some seca providers
-fixed smartcard activation for some seca providers
1.3.0
-fixed some 64 bits issues
-fixed radegast provider id and nano field
-reduced binary size
-immediately interrupt lengthy emu calculations when zap takes place
-userinfo was not correctly reread, therefore you needed to restart CCcam when certain parts of the userinfo changed, fixed
-it is now possible to block a channel for a client, based on caid:id:sid see F entry config for an example
-changed emu share limits behaviour, <1.3.0 an emu matched a F entry limit with {caid:ident:n}, for any nonzero ident. >=1.3.0, an emu only matches {caid:0:n}
-added '-l' cmdline option, to disable all 'self-learning' stuff. This option might avoid problems with irdeto smartcards
-ports 15000-15004 and port 14000 are now gone. Use 16000 and 16001 (html) instead
-implemented workerthread pool to handle client requests, to improve handling larger numbers of clients
-added support for cryptoworks camcrypted cards (incl arena tv). IPK handing is internal, no need for external keys and such
-added support for BEEF patched cards using nagra over seca tunnelling, add id's in config file(see example)
-added conax smartcard support (ecm+emm)
-added entitlements for cryptoworks and conax smartcards
-allow emm one extra level
1.3.1
-7025: several bugfixes
-7025: decoding of all 8 channels (1.3.0 only 4)
-fixed viaccess smartcard
-fixed stealth mode, also set per N line now (see CCcam.cfg)
1.4.0
-implemented irdeto camkey setting
-runtime dvb api version detection
-implemented share limits on client side (just like server side), see CCcam.cfg for details
-implemented load balancing between identical cards, see CCcam.cfg for details
-finetuned tcp behaviour and settings, saving some network load
-fixed newcamd connection emm
-seca smartcard entitlements fix
-irdeto smartcard emm fix
-removed -k cmdline parm, use config file instead
-cmdline parms could previously be overruled by rereading cfg file, fixed
1.5.0
-improved dvb api detection (for systems with both demuxapi and dvb devicenodes)
-avoid exit on systems that provide nonworking dvb devicenodes
-avoid blocking on nonworking newcamd connection (since 1.4.0)
-added column in client info output to see the ecm time per client, only available if SHOW TIMING is on
-reworked share and provider info into tabular form
1.6.0
-fixed wrong irdeto camdata default (since 1.4.0)
-implemented irdeto camdata setting
-improved self learning for irdeto
-fixed constant cw
-added biss support
-added priolist support
-max C / F username length now 20 instead of 19
-max C / F password length now unlimited instead of 16
-switches to enable/disable web and telnet info info interfaces
-implemented authentication for web and telnet info interfaces
-Note: the web and telnet info port paramater have changed name in the config file
-Note2: /var/keys/CCcam.ignore does not exist anymore and /var/etc/CCcam.prio is the new one
1.6.1
-fixed irdeto camdata setting (setting was not used correctly in 1.6.0)
-CCcam.prio: nagra caid:ident entries with nonzero ident now always match
(nagra ident is unknown at time of prio check, see CCcam.cfg for details)
-few small workarounds for buggy 7025 scidriver
-show share (nodeid_handlerid) in ecm.info
-tps.bin support (fixed location /var/keys/tps.bin), using systemtime
1.6.2
-fixed crash when reading malformed SoftCam.Key
-fixed possible crash betacrypt smartcard emm
-minor irdeto improvements
-added config option to avoid (hidden) chids being ignored on irdeto smartcard (See CCcam.cfg)
-added timeslots per friend connection, now possible to only open connection for a few hours (See CCcam.cfg for example)
-Nagra emu fixes
1.7.0
-fixed password bug (consider using "MINIMUM CLIENT VERSION: 1.7.0" to avoid risk)
-added viaccess smartcard emm
-added support for gbox indirect/local connection
-added optional ip address/hostname to F: line, no ip given allows the connection from all ip's (See CCcam.cfg for example)
-tps au (tune to Hotbird transponder 10873 vertical)
-added smartcard custom post-init (see CCcam.cfg) Currently only T=0 supported
-support to override detected dvb api version
-support sc8in1 (note: PHOENIX READER PATH --> SERIAL READER in CCcam.cfg)
1.7.1
-several smartcard fixes
-conax ca pin support (use 'PIN:' in CCcam.cfg)
-added SMARTCARD WRITE DELAY setting, to tweak performance on mastera/sc8in1 and such
-moved providernames to an external file /var/etc/CCcam.providers. Format is 'hexvalue "providername" comments'
-channelname can now be displayed in webif instead of caid:ident:sid when defined in /var/etc/CCcam.channelinfo
-demuxapi support dropped
-gbox indirect: reuse slots
-avoid glitch when zapping over recorded channel (7025)
-two cam devices on DM600
2.0.0
-removed gbox_indirect support
-added gbox support
-several smartcard reader fixes
-fixed LOADBALANCE parsing (broken in 1.7.1)
2.0.1
-changed G: line syntax, see CCcam.cfg for details
-multiple G: lines on the same local port supported
-each G: line can have different localhost
-each G: line can have different pass
-sharing between G: lines supported
-nagra2 MECM
2.0.2
-nagra fixes
-irdeto camcrypt
-tps au
-cryptoworks keys no longer hardcoded
2.0.3
-nagra fixes
-G line remote sharing fixed
-allow more limits in C/F/G
2.0.4
-support more than one emm listener (see CCcam.cfg for details)
-tps au fixes
-nds sc init fix
2.0.5
-global share limits (see CCcam.cfg for details)
-global minimum required downhops setting (see CCcam.cfg for details)
-n2 AU fix (/var/keys/ROM120.bin required)
-cryptoworks sc fix
-90f sc fix
-viaccess sc emm fix
-changed 'double client login reject' mechanism
-G line local sharing fixed
-graceful shutdown
2.0.6
-ignore errors on emm demux (caused n2 AU to abort on certain hardware)
-tps au fix
-various optimizations; avoid server slowing down because of slow clients
2.0.7
-fixed camcrypt on static (non-openssl) version
-fixed segfault reading config
2.0.8
-fixed n2 emu freezes with static (non-openssl) version
-improved system selection (making prio file mostly obsolete)
2.0.9
-fixed irdeto chid selection
-dm800 detection
-fixed minor memleak
2.0.10
-improved system selection (based on distance). Note that prios from prio file overrule this and might give worse results
-fixed aborting lengthy request when switching channels
-fixed low audio pid detection
2.0.11 (Latest Version)
-support caid tunnelling
-improved chid selection
Еще раз напомню
форум по этому протоколу, где можно найти все необходимое
Для любителей технической информации - прикладываю своеобразный учебник по этому протоколу. Сугубо технический и на английском
